Time to throw rocks at the M/T drag radials
No, I bleed the clutch and it did nothing. It looks like some clutch fluid spayed under the car.
I tried readjusting the master cyl and it still tries to pull in gear with the clutch peddle to the floor. I dont think its the clutch because it had no slip at all and then just started not disengageing.
I am going to do a slave cyl first and try that.
Originally Posted by 99ta
They work better with a auto!!!
That might be true but if your running a belted radial around the same psi as a drag slick then your collapseing the center of the tread and causing the contact patch to buckle. These tires do not wrinkle!
10 & 11 Second Club
Originally Posted by SMOKIN01TA
man you not givin me very high hopes for good results on my 325's now, i was thinkin about driving over to hub one night and just seeing what shed do in street trim
oh, the spec 4 works good too![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Just ordered a new SPec stg 3 so when I get it in and broke in , I will try again.
I think that they are awsome tires but I was over doing the burn out. On the street I still have to heat the Nittos where as the M/T drags I dont. SO at the track I need to quit burning the M/T;s like I do the Nittos.
![](http://www.intensephotos.com/gallery/d/13336-2/20050506-386.jpg)
![](http://www.intensephotos.com/gallery/d/13240-2/20050506-276.jpg)
I think they may wrinkle a little
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Those are 325/50/15
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#33
I was running them at 15 psi hot and doing a decent burnout, and I couldnt' get them to hook better than bottom 1.8s. Going to try the suggestions here and bump it up to around 20 hot and not overdo the burnout. These are the 255/16s so there's not a very tall sidewall, and I'm figuring they won't wrinkle at all. I have seen pics before of the 325s wrinkle like above.
#34
LS1TECH Sponsor
#36
On the smaller size tires they won't wrinkle hardly at all because the sidewall is alot shorter. My old ET Drags had wrinkle marks all over them after a night of racing but the DR's look like they were hardly stressted. They need to be glued or screwed to the rim on a hard launching car or you will have problems spinning.
#38
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
A buddy has pulled a 1.55 60 foot on a set of 275/60/15 M/T radials on a 95 Formula with 3.73 gears and a TH350 trans with a 3400 stall convertor. I agree, the manual trans cars may "shock" them too much, but I've seen good stick drivers pull consistent 1.5-1.6 60 foot times on them. I may be giving them a try on a Nova here shortly, but I'll stick with my et street slicks for bracket racing consistency.
Derek
Derek
