What went wrong here?
. I didn't lose traction, the slip regulator was off for the first and second run. Why did I get worse times? Is is something as simple as tuning the computer for the mods or is it because the previous runs where in phoenix,az and the dry air helped out. when i raced in phx it was night time and the temps where the same during the day as they where here. I raced at the california speedway in fontana,ca. please someone help me figure out where i went wrong so i can fix the problem. I'd like to take it to another track (1/8) next thursday at irwindale,ca. it's supposed to be less crowded. Second pass 60' 2.071, 1/4 13.583 @ 102.77 air temp around 80
Third pass 60' 2.110, 1/4 13.826 @ 102.13 air temp around 70
humidity was 25% and elevation was 1,100 ft.
the track where i ran it originally was in phoenix,az
the humidity was 10% and elevation 1,250 temps in phoenix where about the same. im really hoping its the computer what is an "AFR" and where can i get it read?
in phoenix first pass 60' 2.137, 1/4 13.607 @ 103.79
second pass 60' 2.122, 1/4 13.556 @ 103.91
If they are not spinning, you must not be leaving the line very aggressively.
I'm not a fan of aftermarket MAFs either...
You can foot brake the car to 3000 rpms at the line with a stock converter? ??
