results after converter, something wrong
Old Jul 10, 2005 | 12:39 PM
matrik's Avatar
Default results after converter, something wrong
Got to the track for the first time with my drag radials after i put in the converter. Before the converter, i ran a 13.27 with a 1.92 60ft at 103.8. After the converter, i ran a 13.21 with a 1.71 60ft at 101.04. My 1/8th before was a 8.51 @ 81.83 and after was a 8.35 @ 80.71. The car felt amazing off the line, but then ran like crap up top. I lost almost 3 mph somewhere . I have some bad header leaks, both sides of the block, which I had before I ran, and then one on the passenger side gasket b/w the header and y-pipe. Other than that, it felt like it was kinda sputtering up high rpms, not pulling very hard. It seems like maybe my optispark is goin out , but I'm not sure. I can't believe I could pull such a better 60ft and only pick up like .06 and lose 3 mph . Any ideas?
Old Jul 10, 2005 | 01:32 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
keep in mind, losing mph can happen when going to a higher stall convertor. The 60 foot time for the et is great, but I'd check out a few things when comparing the slips:
1-what were the temp/humidity/air conditions on both runs? Comparing good air to bad air is worth 1-4 tenths in the 1/4.
2-If your convertor swap revealed other headaches, then examine those. Might need to check your tune, you mentioned opti-spark, etc.
Hopefully you'll get the combo right and get into the 12s
Derek
Old Jul 10, 2005 | 02:04 PM
matrik's Avatar
The air was definetly bad last night, compared to my 13.27 night. It was perfect that night, the previous week, the best I could run was a 13.48, but then with that air, it was a 13.27. When I ran 2 nights ago, it was kinda humid and hot so I guess the air had something to do with it. But I know I need to fix the exhaust leaks and maybe replace my optispark. I never realized puttin a converter in would cause me to lose mph. I know all my friends with ls1's dropped in converters and picked up 1-2 mph, even with goin from a 2.0 60ft to a 1.7.
Old Jul 10, 2005 | 02:11 PM
7 Second Club
so right away you're looking at a 2-1/2 tenth gain based on last times with stock convertor. It should still be another tenth or 2 and I'm guessing your headaches are causing that loss. This is the rule of racing: sometimes you have to work through a few PITA things to realize the full potential of the new modification.
Good luck!
Derek
Old Jul 10, 2005 | 02:51 PM
matrik's Avatar
Sounds good. Thanks alot
Old Jul 11, 2005 | 12:15 AM
matrik's Avatar
Reread your post, and I didn't gain 2 tenths from the converter. I ran that 13.27 on my stock converter on a 1.92 60 ft. Then ran a 13.21 after the new converter on a 1.71 60 ft. Sorry, my post was kinda confusing heh.
Old Jul 11, 2005 | 05:44 AM
XTrooper's Avatar
That's your answer right there. I'll can lose .2-.3 seconds in bad weather.
Old Jul 11, 2005 | 07:44 AM
MNR-0's Avatar
Header leaks will cause loss of power too. You need pressure in the exhaust manifold to push the gases out the ***-end. You are losing velocity and hence torque with leaks forward of the catback.
That 60' rocks BTW. You stood to gain up to 6 tenths with that. What I would give for a 60' like that.
Fix your known problems and go at it again. Also, if you can, log the car using HPTuners.
Old Jul 11, 2005 | 11:42 PM
matrik's Avatar
Wish I could, but its an lt1 and they don't make hptuners for lt1's . Would using autotap be able to tell me anything? I know someone who has it that would let me use it during a run.
