LG Motorsports Heads/Cam package 9.9@132 (Stock bottom end) NA
Originally Posted by Magnus
01-Z and I are duking it out.. i finally got my setup done and took it out today with PSJ to get some shakedowns.
01-Z, DA: +55
60'-1.246
330-3.971
1/8th-6.246
MPH-107.67
1000'-8.231
1/4-9.919
MPH-133.18
Magnus, DA: +1100
60'-1.322 <- on the back tires
330'- 4.005
1/8th-6.284
MPH-106.90
1000'-8.277
1/4-9.967
MPH-132.78
Another nice comparison is this
01-Z:
60'-1.265
330'-4.025
Magnus:
330'- 4.005 <- notice the lower 330'
Anyway, our shootout at mayhem in morocco should be pretty damn close.
I'm sure my car would do a high 9.7 in great air at its current weight with traction. I'll take it out more often when it gets cooler out. Today was t-shirt weather.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Big thanks to www.LGMotorsports.com and www.LS1Speed.com !![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
01-Z, DA: +55
60'-1.246
330-3.971
1/8th-6.246
MPH-107.67
1000'-8.231
1/4-9.919
MPH-133.18
Magnus, DA: +1100
330'- 4.005
1/8th-6.284
MPH-106.90
1000'-8.277
1/4-9.967
MPH-132.78
01-Z:
60'-1.265
330'-4.025
Magnus:
That LGM go fast stuff is just darn good stuff !!!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Makes me want to take the old 99 anniversary out of moth ***** put the old stock bottom end engine back in and play with you guys!!
LS1TECH Sponsor
Movies:
9.96 Pass
10.02 Pass
Touch down just past the 60'..
On the 10.02 pass I think my 60' was about a 1.26-1.27 if the fronts would have tripped it.. too bad I screwed up the shifts.
9.96 Pass
10.02 Pass
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#37
nice passes..
FYI, most 60ft reflectors/clocks are located about 8inches or so off the ground... from the video, it seems you triggered the 60ft clock with the middle of your car.. probably around the door area... the ONLY way you will truely trigger the 60ft clock with the rear tires is going by them almost vertically..
again, nice passes
again, nice passes
