Predict this car's ET and trap
Old Dec 27, 2005 | 11:53 PM
Speed Kills's Avatar
Default Predict this car's ET and trap
car in question (94 Camaro LT1/A4) has-cai,headers,catless 3 inch magnaflow,lt4 valve springs,1.6 rr's,electric w/p,lca's,air foil,ported maf,custom tune,2800 vig stall, stage 3 4l60-e,aluminum d/s,3.42 gears,lt4 starter,lt4 km,trickflow intake elbow,double roller timing chain, Will have installed air flow research 220cc heads(flow 303 cfm @.6),custom grind cam(234-242 112 lsa),ported lt4 manifold,walbro 255 pump,30# injectors,fuel presure regulator, adjustable panhard rod,adjustable tourqe arm,comp r lifters,manley race flow valves,manley springs,manley locks,manley titanium retainers,chromemoly pushrods, and arp head bolt kit.
What do you guys think?
Old Dec 28, 2005 | 07:41 PM
sleeperstyle's Avatar
12.5 @ 110mph
Old Dec 29, 2005 | 12:05 AM
02blkws6vert's Avatar
13.7@104
Old Dec 29, 2005 | 12:28 AM
Roarin_8's Avatar
What kind of tires?
Old Dec 29, 2005 | 02:54 AM
BlackHawk T/A's Avatar
Originally Posted by 02blkws6vert
13.7@104
I think you completely missed his heads/cam...
I'd say 12.2 @ 115.
Old Dec 29, 2005 | 05:05 AM
bad95killer's Avatar
Mid 12's @ 114mph
peace
Old Dec 29, 2005 | 10:03 AM
Bitemark46's Avatar
What's the weight and rwhp? And on what tires? -Mark
Old Dec 29, 2005 | 02:27 PM
No RWHP numbers, just fueling a discussion held on another board. Said member was claiming he will have mid 11 second timeslip with that setup listed (this is only on paper mind you, not a real setup), and called my setup as being false, even though it runs, I have video, and timeslips.
Thanks guys!
Old Dec 29, 2005 | 08:42 PM
Freaklt1's Avatar
If I didn't run 11's with the above setup I would probably run it off a cliff.
