At 2600 pounds what would I run?
Old 02-13-2006, 06:38 PM
Clean94Z's Avatar
Default At 2600 pounds what would I run?
The car I am building should weight about 2550/2650 with me in it. A ls1 M6 with full exhaust and all the bolt-ons what do you think it will run?
I'm guessing stock motor 10.9/11.0 at 122/124 range {340/350rwhp}
with a f13/f14 cam 10.4/10.6 127/129{405/415}
H/C 10.0/10.2 130/134.{440/450}
But what do you think?
I know most 01/02 m6 ls1 38xx pounds run 12.7/13.0 at 109/112 range and I would be weighting 1200 pounds less.
Old 02-13-2006, 07:05 PM
The1N_only's Avatar
wow, that is extremely light...
Old 02-13-2006, 08:24 PM
Bad Habit Bird's Avatar
Very light indeed! I would think you might start having problems hooking up with it that light.
Old 02-13-2006, 08:50 PM
Clean94Z's Avatar
Because I am using the LS1/t56 vs the factory motor and trans the car will actually get closer to a 50/50 weight setup.
Old 02-14-2006, 11:34 PM
SUX2BU's Avatar
Do you realize exactly how much work and $$$ its gonna take to get your car that light?
Old 02-15-2006, 12:40 AM
Dustin's Avatar
Yah thats gonna be a hell of a project!!
Old 02-15-2006, 01:08 AM
The1N_only's Avatar
hell that's lexan glass, carbon fiber body panels and all... and that all cost big $$$, you dont mind me askin... Why so light with just a mild head and cam package? Are you tring to stay with in a class?
Old 02-15-2006, 06:48 AM
Clean94Z's Avatar
That is with the driver in it. And Im not worried about cost, the car itself will only cost a grand. What do you think it will run? No class or rules to follow.
Old 02-15-2006, 09:07 AM
bad95killer's Avatar
Super light car & i'm sure ya could run low 10's all day long
keep us updated .
peace
Old 02-15-2006, 07:35 PM
SUX2BU's Avatar
Well the fastest SI car ran 10.9's at about 300 lbs heavier than you "should" be.
Fastest cam only car runs 10.2's at about 400 lbs heavier than you "should" be.
and the fastest H&C cars runs 9.90's at about 200 lbs heavier than you "should" be.
If you actually get the car that light you should have no problem being the "record holder" for all three of those categories.
Old 02-15-2006, 08:04 PM
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
If you're going to be at 2600 lb race weight,I hope you only weigh 100 lbs.
Let us know when you get your car done.It will cost shitloads of money to get that light.
Sounds like a cool project.
Old 02-16-2006, 05:39 AM
Race your car!
JL ws-6's Avatar
Are we even talking about a 4th gen f body here, or another car? I have seen what I would call one of the lightest cars built, a red car that eastside sold before they ever got it to the track, and it had glass hatch, hood, every single thing gutted out of it possible, TONS of work done to it, and that car was gonna be 2800 with driver with a awesome pro stock style cage... with a regular 10 point it would have been probably about 2700... to have a car in the weight that you are talking, I don't even know if it's possible. This car has spindle front suspension, struts, no double a arm, lexan glass, a fiberglass dash, a 3 gallon fuel cell only,no wireing at all, other then what was needed to run guages and computer..... just don't see a car getting to 2500.
Old 02-16-2006, 06:53 AM
Clean94Z's Avatar
The is not gonna be a f-body. It's a lighter car with a tough stock rear end. I have owned a few cars in my day and thing it is the perfect combo.
Old 02-16-2006, 07:36 AM
Race your car!
JL ws-6's Avatar
Fox body then I assume. I didn't think you were planning on getting a 4th gen f body to that weight, all makes sense now.
Old 02-16-2006, 03:31 PM
1999TransamWs6's Avatar
yea things make better sense now that your saying its not in an f-body because that is way too light I couldnt imagine that weight with driver.
Old 02-16-2006, 03:53 PM
The Juggernaut's Avatar
2600 raceweight F bod (with driver140-150) is doable, but very expensive and not fun to look at.
Old 02-16-2006, 04:00 PM
Race your car!
JL ws-6's Avatar
Probably be one ugly car... probably not even easy to tell what it's supposed to be at that weight
Old 02-16-2006, 06:25 PM
Clean94Z's Avatar
So what will it run you think?
Old 02-16-2006, 10:02 PM
next's Avatar
Get the car to hook a 60' in the mid 1.4s to upper 1.5s and you'd be looking at a 10.3 - 10.55 range for that weight and 350rwhp.
Old 02-16-2006, 11:07 PM
7 Second Club
Phil99vette's Avatar
Sounds like a 93+ RX7...
Quick Reply: At 2600 pounds what would I run?
