ffhp 347
Really tho, I wonder if ffhp forgot to do the valve job I paid for them to do when I had them do my motor.
Have you done a compression test with the engine warm? If so, what were the results?
What were the cylinder leak down #s for each cylinder with the engine warm?
What's your fuel pressure during the runs?
Have you monitored your runs with a real time scanner to log for KR, LTRIMs, etc?
There are WAY too many things that could be going on to immediately blame the rotating assembly.
Get a compression test at operating temp, then move to a leakdown at operating temp before swapping on different parts that aren't gonna change what's currently going on.
Vibrations could be due to TONS of things:
rotating assembly
clutch
broken motor mount(s) ... to name a few.
I really hope it is not a lifter, since it was a lifter that cost me my last motor. Then all of my fears about this motor will come true. I have very little doubts with the bottom end of this motor, I know that they are almost bulit proof. I never said it was the rotating assembly It is the top end, which I paid him to fix and put together, that I am more scared of.
Hell, if it turns out to be nothing they did, then I'll post an apology to them. I do not want to be a dick (probably a bit too late), but shelling out a lot of money for a motor, and then running worse than my last one makes me paranoid.
Why even start a post that insinuates "x" place did this or that until you have actual data to support it? It's obvious that none of us, including you, really know what is going on with your car. I think it's only fair to first gather information through a post that ASKS for help instead of first insinuating "X" place wronged me but I dont' really know what's going on with my setup. Off my soap box now...
All we know is:
-It makes a bad vibration that started out soft and is now much more severe at high RPMs.
-You ran slower on two seperate days prior to the fastest times 3 weeks ago.
That is far too little info to assume it's secondary to FFHP or any other person that did work on the car.
Are there any noises that the car is making? Ticks, knocks, billowing of any smoke (white, black, blue).
How does it drive otherwise (aside from the shaking)?
Does it only shake at high RPM launches?
Any metal shavings in your oil?
Poor idle compared to normal?
Backfires, stutters, etc?
There is tons of data still not accounted for before we can try to get you in the right direction. The more info you can give us the better
All we know is:
The heads are Patriot, and let me give you a little history on what happened. I installed the heads in the summer of 04, took the car to Chi town to get it tuned, and shortly after that was getting on it to merge into traffic when I heard a nice smacking noise. Which turned out to be one mushroomed lifter, one bent pushrond, one totally fragged rocker arm, one scarred cam and two scarred pistons. Anyway, along with the motor, he offered to fix my heads, and install them with the top end for a great price on top of the motor.
On with the **** at hand. There is some valvetrain noise, not a lot but some. I figured, along with a mechanic friend of mine that it is normal, especially with big cam, dual springs, and harland sharp rocker arms. Hell we could be wrong, and I just screwed it up even worse by racing it. I'll put a stethoscope to it to see if it is all the same or louder anywhere. It idles great, better than the old cam. No smoke, and the occasional stutter under normal driving conditions, and it did give me a nice backfire last night on my last pass coming out of first. The vibration is only at high rpms, and since I never launched it at that high an rpm is why I asked if it was normal. Have not noticed any metal in the oil, but have not checked in 2 weeks. No lifter tick, no smoke, and is there any thing else you would like to know.
Really tho, thanks SO much for the help. I tend to get pissed and fly off the handle, especially once I am frustrated. And I passed frustrated 3 months ago
The occasional stutter that you get, has that been present since your fastest run 3 weeks ago?
Regarding the backfire, did you ever have this before in the 3 weeks prior?
Is the vibration at high rpms only when you're holding high RPMs for a launch or will it vibrate if you're crusing down the road at high rpms also?
"SCALPEL" ???? nice name, i like it!!!
PS. allready tired of the Z? WTF Levi?
:endhijack:
