Cam-Only TA - I ate a 505hp Z06 Corvette!
1 Post
We were both spinning on the tires, I was not sure if I would beat him. I ran a 7.70 spinning all the way through the 60' and he ran a 8.0. This was when my tranny was at 180* and it was 95* outside. Usually my car runs 7.4s. The guy insists that I have nitrous somewhere; I told him, "Go ahead and look for it". I promise, I only have a cam and a stall! So it is now confirmed I am hitting somewhere around 500 now. This is going to be a great year. UNBELIEVABLE heads coming -
I run 7.40's also.... but I run a 1.9/2.0 60ft.... I make it up with the nitrous!!
Originally Posted by Forteen3GT
no way your car is at 500 cam only.... you beat a 490 hp car that does not have the tires or stall you have. Good Kill.
So is the time in your sig on the gas or NA?
1 Post
Originally Posted by AOC
You beat the driver. I've seen a horrible driver make a slow pass of 12.7@121 with C6 Z06. Some people are just too afraid to take their expensive toys to the limit.
1 Post
Originally Posted by s346k
sweet, my bolt-on car is "hitting around 500" too, i run 7.7 in the 1/8
with nos i'd be like 900!!!!!11!1!!!1
1 Post
Good kill. I took a new Z06 last week coming home from work...I didn't want to play on the street but we went from a 25 mph roll...I had him by 5 to 100 then got out of it..He flew by and flipped me off!!! oh well...Those things have wicked top end...Guess he was mad to lose to a lowly LT1...
--Alan
--Alan
Originally Posted by 30th t/a
i hope some of you people know the rwhp has more to do with MPH....not ET. ET has alot to do with suspension and hooking up.
a new Z06 with tires & driven the way it should be would MURDER a cam only fbody.
good kill none the less!!!
--Alan
There are quite a few cam only cars that can scoot a ZO6 on any tire. I want to see a cam only ZO6 hit the track with a tire. I am thinking a full BO with a big cam, a tire and skinnies could crack a 9 with a good driver. We have already seen over 600rwhp out of these with suposed "mild" cams. Oh a gear would help too since they run 11.7 and better with 3.42s and street tires stock. And these are with the first couple cams. Wait till they get more dyno and track time with them to create even better cams. I am not about dyno racing but a before and after difference will show the numbers at the track.
Honestly, a ls7 vette with a tune, boltons, some gear, tires, and a drive line that will hold would be 9s with no problem i'd certainly think considering how they run with none of the above and how that motor should respond to bolt ons. Those things are animals. Put a cam in one and
King of the radial tires
Nice Kill, fasttagurl.
When two traction-limited cars line up, the winning car usually had the better driver.
A stock C6Z06 has Torque Management in the ECM to protect the drive-train. This makes the car weaker in the 60' and 330'. But it regains full power after that.
Mine has been running 6.31-6.40 for the 330'-1320'. And it's run 11.20 127.55 at a 1600' DA. That was on a 1.84 60' and 4.89 330'. 660' was 7.28 101.95
Run enough C6Zs and eventually you find one with an experienced driver.
Ranger
Ranger
