Track update on my LS7 Firebird
Old Aug 1, 2006 | 09:45 AM
vmax1500's Avatar
Originally Posted by CHRISPY
Andre, great ET/mph!
You are still planning on running on the street right? I would go TH400 if you are going to drive the car on the street a fair bit. Also you are a little on the heavy side for the glide imo.
Best of luck with the car, I think you have just scratched the surface with it
The glide itself saves close to 50lbs... and with my new hood and a couple other little things I will get the car just under 3000lbs... it should work well with the glide, especially with the spray... Wade is the one setting up the car, so if he says it will work... I am confident it will
And yes... I will still cruise around town with it
Old Aug 1, 2006 | 01:13 PM
CHRISPY's Avatar
Is that under 3000 pounds with you in the car?
On motor you'll gain a couple of advantages with the TH400.
1) Able to run a slightly tighter converter compared to the powerglide and run a similar ET (deeper first gear)
2) Better manners on the street
3) Better ET potential NA
On the spray the glide would work well for sure. If your raceweight was 2500 pounds and you were running a 5000 stall nitrous converter then the glide would kick ****. jmo of course
Cheers,
Chris
Old Aug 1, 2006 | 01:45 PM
1Bad97WS-6's Avatar
Congrats! nice a 9s street car. I just like to get my LT1 in the 11s on motor. Then hook the spray to it and run 10s.
Old Aug 1, 2006 | 03:23 PM
bad95killer's Avatar
Originally Posted by vmax1500
I got the track photographer to remove the watermark from the photo above
Awesome launch man & Congrats on 9's pass buddy
peace
Old Aug 1, 2006 | 03:30 PM
vmax1500's Avatar
Roofer Tom went 9.81@138.35mph 1.30 60 ft. with his 421LS1 NA and a glide... I don't think his raceweight was 2500lbs
Anyways... Wade has put together enough winning combinations, so I am not about to second guess him...
There is still more power to be had out of my 427LS7...
Cheers,
Chris
Old Aug 1, 2006 | 05:47 PM
slmdLS1's Avatar
awesome times for a street beast!
Old Aug 1, 2006 | 09:05 PM
WILWAXU's Avatar
Sweet car!
Runs alright too
Congrats man!
Old Aug 1, 2006 | 09:12 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
I agree that sometimes a glide can be a blessing. Sometimes you want less of a "hit" on launch, and a glide provides that. Hell a friend that has a pump-gas mild 434 SBC and a 3800 stall converter behind a glide has gone 1.42 60 foots at 3200 lbs on a 10" tire. So they can be done, although I agree that street driving a glide takes a little getting used to.
Derek
Old Aug 1, 2006 | 09:34 PM
vmax1500's Avatar
At this stage of the game, I am not looking for it to be a daily driver... just to get to the donut shop on cruise nights i
Derek
Old Aug 1, 2006 | 09:36 PM
guitarisawesome's Avatar
wow...thats incredible. I need your car for a little while just a little test drive?
Old Aug 2, 2006 | 12:42 PM
Tom the roofer's Avatar
My race weight at the time was 3,350. I have a 1.96 1st gear in the glide. 4.56 gear in the rear and a 30" X 10" tire.
Nice runs man. Your car looks great.
Old Aug 2, 2006 | 12:56 PM
  #32
vmax1500's Avatar
Thanks Tom!
Roughly how much power was your car making when it ran 9.8's?
My race weight is currently 3400lbs, but I am working to get it down to 3250lbs by the time the glide would go in... My 427 makes about 650HP at the crank, and I have TNT Ring kit on the car as well (100-250HP). I have 4.10's and plan on running a 28x10.5 MT stiff sidewall slick... Do you think a glide would work well in my car, and what would you reccomend converter wise... something that would work on the motor as well as with a small shot...
Thanks again!!!
Old Aug 2, 2006 | 01:38 PM
  #33
around 540 rwhp and that was in decent weather for Pittsburgh. Around +1,700 DA
Old Aug 2, 2006 | 01:50 PM
  #34
vmax1500's Avatar
Good to know... we are in the same HP range My 3 disk current nitrous converter and 4000FT DA are killing my NA times (10.5@129)... I would love to see 9's NA in better air, and I think that the right tranny/converter choice might get me there!
Old Aug 3, 2006 | 04:30 PM
  #35
67Firebird455's Avatar
Dude, that is absolutely INSANE! That car fires the hell out of the hole! You're probably gettin the 60' timer with your back tires!!!! =) Way to go man, that car is SWEET!
Old Aug 5, 2006 | 11:29 PM
  #36
vmax1500's Avatar
So I went to a track.in Montreal today for my second outing with my car... Same setup as last weekend with the 150HP jets still in.... I did 3 spray and 5 motor passes.... All within a tenth of each other! Best spray pass is 9.6@147.8 1.46 sixty and 10.4@136.1 1.51 sixty on motor... The DA was much better than last weekend but track prep was not as good.... I'll post slips and videos soon!
Old Aug 6, 2006 | 12:49 AM
  #37
FormulaFire's Avatar
I'll trade cars with you.. Keep it up.. And when you get that sucker rolling.. Up the jets!!!!
Old Aug 6, 2006 | 10:02 AM
  #38
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice. 9's on motor and 8's with spray has a nice ring to it.
Old Aug 6, 2006 | 10:12 AM
  #39
vmax1500's Avatar
Thanks I checked the DA and it was 1000ft for my NA pass and 1300ft for my spray pass.... My slicks are pretty worn and have a net set for next weekend... There is still 150lbs to be taken out... My OD tranny and hydraulic cam are holding me back... Has anyone run 8's with with hyd cam & OD tranny?
Old Aug 6, 2006 | 11:32 AM
  #40
LS1Tech Co-Founder
Actually Steve Drumheller (sp?) who had that LPE TT C5 (pewter FRC) went 8.9 with 4L60E.
No f-body has ever run 8's with a OD trans.
