LS1 Mustang Results
Thanks again for the comments.
The list was copy/pasted in here. I made it 6 months ago.
As far as a conversion kit. Im sure someone will come out with one soon. There is alot of demand for it. Id expect one of the k-member companies to do it first because there is no direct bolt in k-member yet. Every option used by people on this board requires some amount of custom work.
Not sure it will work on a fox body, but when I did my SN95 swap I extended the mass air wires , and mounted it on the pass. side inner fender as a homemade cold air kit. My full weight 95 mustang with a 2000 ls1/a4 swap has gone 11.8 (all motor, 10.85 w/100 shot), so I don't think you will have any problems getting into the 11's
Jamie
Jamie
#35
Originally Posted by H8Mac
I would think u would want the MAF sensor to be closer to the throttle body. So get a better reading of the air going into the engine.. Just a thought
ive heard of the fuel charts getting messed up if there was a large bend before the MAF because the sensor could not get an accurate reading due to the different velositys of air on opposite sides of the sensor...think of taking a turn at 80 mph in the inside lane...then take that same turn on the outside, not only did you feel less force against you but it took you longer to travel the same distance as the inside turn...how would the air change going through a tube, and if any what effects would they have?
#36
As long as the maf is placed in between the tb and air filter and there are no leakes in the tubes it will read fine. No mater where its placed. However like boondiggys said there needs to be straight pipe in front to make sure there is no turbulance at the maf.
#38
#40
Originally Posted by JD_Z28
Nice car. Do you get alot of **** from ford guys when you pop the hood.
