M/T DR didn`t work!!!
#41
Originally Posted by MADMAN
Never mind I found it. Its the suspension. Those tire will net you killer 60ft if you get some good suspension parts. Alot is in the shocks.
Thanks.
#42
Originally Posted by bad6as
12.5 with a 2.0 60ft.
hum what am i doing wrong?
j/w what was your wheather like?
#44
I would start with a set of QA1s first. Is the car stock height or os is lowered?? What angle are your control arms in rear??( are they running up hill from the rear end to the body)
as for shocks , do i need a set of 4? for front and rear? shall I go with the spring shock package? what spring rate is recommanded?
Thanks.
#47
I would get all 4. For you application I would get 325s for the front spring.
#48
Originally Posted by jerflash
listen to mad man
im pullin the wheels with 255/50/16s on my m6 ws6 with his advise
i just have to do some more little tweeks to get everything perfect
Thanks.
#50
King of the radial tires
Originally Posted by prostock_bigblock
well the way i did it is setting the tire pressure at 15 psi( thats for the best run) and did a reasonable smokey burnout , steped on the line and holded the clutch at 2600 rpm and slipped it .( I tried dumping , but 60` was worser) .
stock springs and shocks too.
If other drivers with similar set-ups are able to get 1.7x-1.8x from MT Radials, why can't prostock_bigblock?
Is the hypothesis that the his rear shocks are worn out? Other drivers on stock shocks seem to run faster 60'. Is it the shocks? Or is it a technique issue?
prostock_bigblock did not answer the question is his car bogging or spinning. On a Corvette, to make properly heated MT Radials to spin took 2000 higher launch rpm than on stock tires; for me that meant 4600-5200. It is very difficult to imagine that prostock_bigblock is not seriously bogging his engine on a launch of just 2600.
Ranger
#51
Heres a video I made. You can see the tires work great. Get that suspension done. It was one of the best things I did to my car.
Oh BTW, I am a big fan of the BMR extreme sway bar and QA1's. You will be able to see the car used to twist bad. After we did all the suspension stuff she went up straight in the air the first night out. Thats the last shot in the video..
https://ls1tech.com/forums/showthrea...16#post5498916
