New best!
60 FT: 1.8123
330: 5.1119
1/8: 7.8258
1/8 MPH: 89.13
1000: 10.1781
1/4: 12.1784
MPH: 113.18
I actually spun a bit on the launch, and still cut a decent 60, and man, the Yank certainly helped solve my low MPH problem. All in all, a satisfied customer, and a happy drag racer!
Glad to see that all that frustration with the tranny may finally be solved. Well, looks like I really have to get my *** in gear and swap some parts to be any kind of match for you. Maybe soon?
Congrats on the new best time.
Looks like you have an 11 second car!
01_ram-air is correct in saying that you need to get the sixty foot down. The reason why I say you have an 11 second car is the fact that you stated in your post that you spun. I checked you times against mine runs from last week and found this. The only difference here that I see is my track has an elevation of 1085 feet and your in Texas at a lower elevation. My car has a stock cam and a LS1 intake with 91K miles on it compared to your aftermarket cam and LS6 intake.
Your time My Time
60 foot 1.812 1.616
330 foot 5.111 4.880
594 foot 7.141
1/8 mile 7.826 7.645
MPH 89.13 89.25
Now as you can see if you would not have spun you would have covered the first 1/8 mile faster and got you 11-second time slip. If your faster in the first 1/8 mile your faster all the way through. Your 1/8 MPH is a little higher than normal due to spinning the tires. Of course you did not say that you wanted an 11-second time slip you said you were happy with the results of the converter swap. It appears you have a better setup now than you did.
You should be able to change your 12 second club to 11 second club very soon with a little more track time. Good Luck and have a great time!!!!
Ill sell you my 15x8 Draglites with 26/10 MTs with rim screws for a good deal.That will get you in the 11's for sure. Then you can shoot for the 10's on the dope. I got to get some 15x10s for for 28/10.5 MTs. Give me a call Ill hook you up. Last edited by JaSSon; Nov 12, 2006 at 09:16 PM.
