"Fastest Stock Bottom End" List
Old 12-27-2006, 06:47 PM
Charles Cyrus's Avatar
Heres my stock bottom end on 100 shot.
Charles Cyrus, 10.13@132.57, 1.50 (60ft), '01 WS6, TH350, 4500, 3.73, F-13, PP stage II 5.3s, NX-100, Race Weight-3175, 11/06.
Old 12-28-2006, 07:59 AM
PewterZ28's Avatar
Charles Cyrus, 10.13@132.57, 1.50 (60ft), '01 WS6, TH350, 4500, 3.73, PP stage II 5.3s, NX-100, Race Weight-3175, 11/06.
Cam?
Keep them coming guys!
Old 12-28-2006, 09:16 AM
Originally Posted by PewterZ28
Cam?
Sorry! Fixed it, F-13.
Old 12-28-2006, 09:46 AM
ls1 joe's Avatar
We actually went 10.11@134.85mph stock bottom end with Heads and cam.
Thanks,
Amber
Old 12-28-2006, 11:06 AM
Bryan @ Speed Inc.'s Avatar
I personally am not going to throw a fit about weight because the other two lists have no weight limit either. However, a cage and stock rod bolts should be required.
Stock rod bolts were voted off by the cam only guys but the topic eventually died with nothing being ruled. Sometimes people have a way of becoming famous on this website and the majority opinion gets ignored when the subject being discussed does not favor them. Aftermarket rod bolts is not stock anymore so quit whining about it. So until rod bolts are not considered part of the bottom end, they should remain stock.
A cage should definitely be required also. I thought everyone on the cam only list had a cage but maybe just those of us who actually follow the rules. That's too bad. Sorry but at respectable drag strips across the country you can't run these times unless you are legal. So I guess those of us who run at legitimate drag strips are supposed to drive down to hickville every time we want to make a pass instead of getting a cage and being able to run at our local drag strip? I don't think so. Save yourself the embarrasment and get a cage. You're not going to impress anyone running quick times in a tin can without a cage. Matter of fact, where I run you get one 9 second pass and then you have to get licensed. I'm willing to bet the top 10 power adder's on the stock bottom will all be in the 9's.
So I say weight limit, no. Aftermarket rod bolts, no. Cage, yes! This isn't the stock internals list.
well it's your personal list - so make the "rules" the way you see fit. i don't think a lot of people are going to give up good rod bolts (cheap insurance) to make an unnoficial internet list. "this isn't the stock internals list" exactly! who in their right mind would run a h/c power adder car w/ stock rod-bolts??? you should just make it the "who's the biggest yet luckiest dumbass" list.
Old 12-28-2006, 11:21 AM
ls1 joe's Avatar
Well we made 518rwhp and ran a 10.11 with STOCK ROD BOLTS. When we took the engine apart it looked brand new. No bearing wear and no issues with the rods.
Amber
T56Rebuilds.com
Old 12-28-2006, 11:25 AM
PewterZ28's Avatar
LOL I agree that throwing that kind of power at the stock rod bolts is very risky but they are part of the bottom end aren't they? So if this is supposed to be a STOCK bottom end list, why should we allow aftermarket rod bolts? This isn't MY list per say but I am willing to get it started and updated since no one else has taken the initiative. If a lot of members are going to fuss about this then maybe we should allow it? Should we start another thread and take a poll? Let it run for a week and then make a decision?
As for the cage, I'm not budging on that one. Be happy I'm not demanding the car be licensed too. J/J
If a lot of people (I doubt it) are going to fuss about that one too then they can go start their own list.
Old 12-28-2006, 11:30 AM
Amber
T56Rebuilds.com
i wrote my post with that in mind... that is very risky to me, and even though your motor looked brand new... do you think that is everyones luck??? (no attitude, i genuinely think that your motor is a freak of GM nature!)
also - you aren't running a power adder. so that helps keep her alive.
good luck with your new project. should be SICK!
Old 12-28-2006, 11:37 AM
about the cage - yes it should be there just for the safety of our LS1tech'ers. i see your point about not being able to make passes at the track without the propper safety equip. (therefor not being able to test and tune to fine the right setup) but that's not the issue for everyone. i know of 3 tracks i can go to that don't really give a hoot about the safety equipment as long as your battery is kept down and your wheels and tires are straight. those tracks are all 1-1.5 hours from me.
rt 66 is still 45 minutes away, and i prefer not to go there becuase of the crowded staging lanes.
if you are being so literal about the STOCK bottom end (not wanting to allow aftermarket rod bolts) then that's what you should stick to. regardless if it's NHRA legal, or not. if it's got a STOCK bottom end ls1 in it, then it should be able to qualify. i think we all want to keep it F-bodys and vettes though.
Old 12-28-2006, 11:44 AM
PewterZ28's Avatar
Joe/Amber, I need more details. Type and size of Heads? Cam name or size? Raceweight? Etc. I can put you at the top of the NA list once I get those details.
imslow, as I said I can start a poll asking if rod bolts should be allowed but unless I hear a ton of bickering about the cage I'm going to say it is required for now. If need be we can start a poll for that too but I honestly think most are going to agree with me on that issue. I've been known to be wrong every once in a while though.
Old 12-28-2006, 03:04 PM
CARTEK Racing
WS6TransAm01's Avatar
Ill throw my slow POS into the mix. Since Joe and Amber stole my thunder by beating my Heads/Cam HP record [508RWHP] I cant lay claim to anything. LOL
But with my CARTEK 4X Heads/Cam [LS6 Heads] a 3325-race weight, stock T56 and stock bottom end I ran 10.51 @ 130.78
Old 12-28-2006, 08:26 PM
  #32
URLOSN's Avatar
Here's mine, power adder:
URLOSN 02 WS6 T/A 10.25@130.5mph 1.37 (60') TH350, 4000 stall, 3.73 gears, 232/236 .599/.603 114+2 FMS cam, Home ported 5.3 truck heads, bigger valves, NX MAF 150 shot, 3550 race weight, No Problem Raceway 11/05 and still running strong as ever. even stock rod bolts
Old 12-28-2006, 11:00 PM
  #33
NOSWS6's Avatar
power adder:
NOSWS6---9.89@136.46 (1.42), '98 WS6, TH350, 5200, 3.89, comp cam 232-228 595-605 112lsa, Katech ported 241 castings, Cold Fusion direct port, 250 shot, 3400 race weight, 11/05
Old 12-28-2006, 11:51 PM
  #34
Justa Z's Avatar
Heres mine:
Tea stage 2 heads, comp 228 232 .575 .585 112lsa, th400 4000 stall, 3.90 rear spool, 175 shot tnt = 9.93 with a 1.39 60' at 134 Ill try to atach a vid
Old 12-29-2006, 12:06 AM
  #35
LS1TECH Sponsor / 7 Second Club
GoldRust's Avatar
Here is a video of "Catapolt"s car. He is one of my techs at HPE. We did this a couple years ago. Heres some of the details. 98 T/A, Heads, cam, th350, 250 shot, 3:73 gears, 28x10.5 tire, BMR suspension set up by myself. The engine actually lasted quite awhile with that much n20. Someone may have been quicker than us by now.
http://www.horsepowerengineering.com...s9.64pass.mpeg
Oh and the front bumper is all jacked up because it got hung up when we unloaded it off the trailor
Old 12-29-2006, 12:24 AM
  #36
Justa Z's Avatar
That leaves nasty, what time's (clocks off)
Old 12-29-2006, 12:27 AM
  #37
GoldRust's Avatar
He went 9.64 @ 141 mph, with a 1.30 60'
Old 12-29-2006, 08:40 AM
  #38
PewterZ28's Avatar
Impressive times and wow to the 250 shot! Please give me as much info as you know. Once again, here is what I need:
For Naturally Aspirated setups:
Board ID - 1/4 ET @ MPH (60ft), Yr & Type of car, Trans, Converter/Clutch, Gear, Heads, Cam,
DA, Race Weight, Date
For Power Adder setups:
Power Adder - amount, DA, Race Weight, Date
Old 12-29-2006, 10:06 AM
  #39
PewterZ28's Avatar
I tried to change the thread title to:
Quickest "STOCK BOTTOM END" List
but it didn't work.
Maybe one of the moderators can correct it and also make this thread a sticky? Seems like there is quite a bit of interest already and the thread is only a couple days old.
Old 01-01-2007, 04:35 PM
  #40
Gimp98TNT's Avatar
Power adder
Gimp98tnt - 9.744 @ 134 (1.36), 98' Camaro SS, TH400, Vig4000, 3.73, PRC 5.3L, Futral FM-8, N20 - 250wet, -500, 3350, 12/1/06
Quick Reply: "Fastest Stock Bottom End" List
