New Cam only bests with my G5X4
Old 01-03-2007, 02:16 AM
spy2520's Avatar
fast ******...
Old 01-03-2007, 07:50 AM
Bryan @ Speed Inc.'s Avatar
Originally Posted by HumpinSS
shifting at 6700 specs on the cam are undisclosed per LG. I just installed it striaght up and went about my business
6700???? have you tried shifting at higher rpms? it SHOULD help. try shifting at 7-7200. a cam that big should probably shifted around there.
jugger had his G5x3 and i believe he shifted at 7100.
Old 01-03-2007, 01:55 PM
PewterZ28's Avatar
I also have the G5X4 and I also get best results shifting at 6700~6800. I think the dot to dot installation could have something to do with it. Mine made peak power a solid 300 rpm lower than several others with this cam and I'm guessing HumpinSS also made peak power a little lower too. Dot to dot is probably ok 99% of the time but what about that slight chance the dot was off a tooth or two?
BTW, nice time and congrats!
Old 01-03-2007, 03:11 PM
weird... sweet times none the less!
Old 01-03-2007, 10:45 PM
JRracing's Avatar
Wow man. That thing is pretty nasty. I'm in the market for some 205s and a cam. Maybe I should call LG tomorrow and talk with them about this cam.
The one I took out was a x3 clone. I sure would like to see what the real thing does. LOL.
And Chad tunes my car.... I'm sure you could get him right up to speed on the tuning. Hmm.
Old 01-04-2007, 09:23 AM
Black02SS's Avatar
I don't know. It is a fairly big cam. We might have to take it to him to get every last HP and make her RUN...
Old 01-04-2007, 10:06 AM
bad95killer's Avatar
Congrats Larry & nice tuning job Chad
Btw did ya hit 7000rpm at finish line Larry or abit more ?!
peace
Old 01-04-2007, 10:11 AM
HumpinSS's Avatar
peace
She is turning about 6600 thru the traps and yes Chad is the bomb tuner but I doubt he had a cable long enough to go from Indiana to Maryland LOL
Old 01-04-2007, 10:15 AM
Black02SS's Avatar
Don't be upset. We all know I do mail order tunes.
Old 01-04-2007, 10:17 AM
Oops i thought the car tuned by Chad anyway good job
peace
Old 01-04-2007, 01:08 PM
BADSZ28's Avatar
Nice times. What was the DA? What do you launch at? I can't seam to break 1.60 60's and my car is very similar. 3600lbs, cam only, M6, 4.56s, 28" tires...I was shifting my car at 6700 then brought it up to 7k and went slower. I have a T-Rex, but the same principal here. These big cams don't seam to make power as high as you would think. Next season I am trying 6500. It peaks at 6300. I am switching to 4.11s and 26" tires though. The 4.56s are just too much. I drive with 26" tall tires on the street most of the time anyhow.
Old 01-04-2007, 01:20 PM
  #32
HumpinSS's Avatar
-515
6200 off the 2 step
Old 01-04-2007, 01:21 PM
  #33
BADSZ28's Avatar
Missing gears sux on good runs. I feel ya.
Do you have the 90/90 yet?
Old 01-04-2007, 01:23 PM
  #34
HumpinSS's Avatar
yup 90/90 only thing i dont have are rockers and an EWP
Old 01-04-2007, 01:34 PM
  #35
ATVracr's Avatar
Rockers?
EWP not worth it IMHO.
Old 01-04-2007, 03:05 PM
  #36
Originally Posted by ATVracr
Rockers?
yea... you can't have aftermarket rocker arms if you're claiming "cam-only"
i also have not heard many good things about the EWP. atleast not for the money you spend.
Old 01-04-2007, 08:51 PM
  #37
JRracing's Avatar
I seen one dyno article that showed the EWP making 4hp. But 4 here and 5 there help get it up to the 450+ range.
How streetable is this cam? Does it make good low end power as well or is it all top end?I talked to Anthony @ LG today.
Old 01-04-2007, 10:10 PM
  #38
ATVracr's Avatar
4 hp for $600
Like I said not worth it.
Put 400 more to that and buy some PRC heads
$1000 = 40 hp or $600 for 4 hp
Old 01-04-2007, 11:22 PM
  #39
HumpinSS's Avatar
Its making 350 ft/lbs@ 3000-3200 rpm its making enought bottom end LOL
Old 01-05-2007, 09:20 AM
  #40
JRracing's Avatar
Not bad. Do you plan on adding heads to it later?
Quick Reply: New Cam only bests with my G5X4
