New best…Finally a 100mph 1/8 mile!
Dom - No dyno numbers. I am not much of a dyno guy. I WOT tune at the track and idle tune at home.
There is not much drivability difference between the cams. Most of the difference was cold starts. I spend a good bit of time tweaking the idle and drivability tune. With a 4000 stall it is hard to tell any difference down low. Up high the car pulls much harder with the 230 cam.
1badnova496 - I am running a rebuilt stock transmission.
Slimcracker - I have been real lucky with the stock short block.
I really do not beat on it too hard. The engine rarely goes above 6500rpm and I run a conservative AFR of 12.2 to 12.8.
John
John
Hey John, have you considered stepping up to a larger cam like I'm running? (Vindicator from Vengeance)
It might turn your car into more of a "race car" than you'd like but I'll bet you'd be happy with the increased performance. Just thought I'd ask.
Smokinstorm - I have thought about going to a larger cam but I would probably have to spin the motor well past 6500 to realize any improvement in ET.
I notice that we run very similar times, what RPM do you shift at and what are the specs of the Vindicator cam you run?
John
John
John
John
I've noticed a few of us are now running almost the exact same ET and MPH. Pretty cool considering different combos, different tracks, different parts of the country, etc. I guess the LS engines respond well to heads and cam no matter who does it. I won't get the chance to hit a 1/4 mile track again before Fall/Winter but I'll post up my 1/8th mile times so we can all compare. Good luck with the upcoming racing season everyone.
