ls1 malibu wagon
1.704 60
5.031 330
7.83 1/8 86.61
10.328 1000 97.80
12.442 1/4 106.36
ran a 12.46 on another pass at 108.04 with a 1.7560
this is carbed,
1 3/4 long tubes
victor jr 750 vac
3.90 gears
275 60 15 mt drag radials
having some minor carb problems, like a hesitation off line,
shirt first about 5600 or it breaks up
shift 2nd about 5800
You using the MSD box? Any pics?
the idle circuit,buterflys, cleaned the carb out about 5 times. bigger squirter,
I just need to figure out how to lean the idle out so it doesnt foul plugs.
110-112 mph would be ok, I just see all these stock internal cars in the 11s, i have a light car,
Let me know if you have any ideas.
I'm guessing you run true duals?
I'd try running no exhaust or cutouts to see what happens. Flowmaster mufflers sound cool but unless but most of their models are restrictive.
I want to put a cam in it this year, but i want to see how good i can make the stock one work first, and i am broke right now lol.
If you are looking for best ET I would suggest a four corner idle mechanincal secondary carb. Vac secondary 750 holley carbs arent the best carbs out there but they do work. Best way to tell if your jets are close is to take off the accelerator pump arm and keep jetting up untill the car just barely hesitates cracking the throttle with no accelerator pump when warm in nuetral. Then run close to that jet on all four corners, its the easiest way to start on an unknown combo..
Good luck with it, nothing wrong with a LS1 'bu wagon
Good luck, and tuning to get the best from it is a part of the game!
Derek
