Vindicator cam only results...
Old Apr 14, 2007 | 05:50 PM
347fairless's Avatar
Default Vindicator cam only results...
Well, here are the track numbers.
Best 2 passes of the day were both 11.71's. MPH were 120.92 and 121.02
60fts for each were 1.71 (bog) and 1.78 (sliping).
All runs granny shifted. Clutch combo wont let me power shift.
No matter how hard I left I could not get into the 1.6's. Launch technique was a fast drop between 5000 and 5500 rpm.
Shift light came on at 6600.
Full weight 17inch MT Dr's
How can I get this 60ft down without compromisng the handling it currently has? Thoughts? Video below.
TA pass at Cecil
Old Apr 14, 2007 | 06:08 PM
venom ws7's Avatar
nice times and great looking car man.
what is your race weight?
and update your sig.
Old Apr 14, 2007 | 08:11 PM
JRracing's Avatar
Nice job.
Old Apr 14, 2007 | 09:14 PM
SScam68's Avatar
VERY impressive considering full weight and the numbers it put down. Car actually backs it up
Any gears? You're bogging pretty good off the line so I'm guessing 3.42's.
Old Apr 15, 2007 | 09:34 AM
4.10's is what I have. I didn't think I should bog with them like in the video, maybe I should step up the gear (4.30)? Was hoping to spray after the summer on these tires (26 in).
Old Apr 15, 2007 | 09:50 AM
30th t/a's Avatar
Thats pretty good I think being full weight with the big 17's all around. Some good heads & a good 60 will get your car LOW 11's pretty easy.
Old Apr 15, 2007 | 02:51 PM
1BAD98LS1's Avatar
Did you have to cut the pistons to install this cam?
Old Apr 15, 2007 | 04:16 PM
Demonicbird00's Avatar
congrats on both new numbers, with practice youll go lower times.
it seems hard to bog of the line since you have full exhaust and 4.10s to boot. your prolly not going WOT fast enough off the line.
-brandon
Old Apr 15, 2007 | 04:25 PM
KCFormula's Avatar
Congrats on the times.
I don't know what your suspension setup is like right now but I pulled a 1.81 with Bilstiens, Jamex springs, BMR sways, 3.73s and 17" FM5s. It was my first time out with the BFG DRs too. I know they have some high to mid 1.7s in them if my clutch will hold out from all the slipping.
Seeing what the MTs can do I'd say your car should do a 1.6 if you can keep the RPMs up a little more when launching. Have you tried playing with the tire pressure or slipping the clutch?
Old Apr 15, 2007 | 10:02 PM
Actually Brandon, I think I have a slow throttle foot when its leaving. Had this issue with my mustang until I got a 2-step.
I was gonna experiment with slipping the clutch during the afternoon but kept dropping it. Seems like I have to do something from the start of day or else my mind wont let me change it.
Old Apr 16, 2007 | 11:29 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
plenty of speed, I'd think with additional traction and a little more practice you'll find the 1.6 60 foot range!
Good luck!
Derek
Old Apr 16, 2007 | 07:04 PM
Photochop's Avatar
Glad to see some track results with this cam! Like someone asked, did you have to cut the pistons to get the cam to fit?
Old Apr 17, 2007 | 02:36 PM
Nope, no need to cut the pistons with stock heads.
Old Apr 17, 2007 | 04:10 PM
Kurtomac's Avatar
if you bogged at 5-5500....dump it off the friggin limiter thats what i used to do
Old Apr 17, 2007 | 07:45 PM
5_02ls1's Avatar
Default lol
i lioke that.....
id say get some 15" wheels for the track
Old Apr 20, 2007 | 11:32 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Decent times, great mph!
