Sprayed my car at the track
Old Jun 15, 2007 | 09:09 PM
BTLFEDSS's Avatar
Default More gear/or Bigger Stall??????????
Went to the track last week.Was not great weather,hot and very humid,DA 2500+
Here are my mods
Lid/Bellows
Ported TB
ASA Cam
SLP Lt's ORY/Cutout
Powerbond Plulley
100 shot 3k on/6600 off
Th 400
PTC 10" Nitrous Converter 2800-3k
10 Bolt 3.42
26x10.5x16 ET Streets
R/T.678
60' 1.729
330' 4.848
1/8 7.442
1000' 9.669
1/4 11.570
MPH 119.09
2
R/T .833
60' 1.678
330' 4.834
1/8 7.445
1000' 9.691
1/4 11.586
MPH 119.06
Best run on motor Different Day before tune
R/T .046
60' 1.824
330' 5.206
1/8 7.987
1000' 10.391
1/4 12.416
MPH 111.23
Does this seem right,figured mph would be a little higher,and E.T. a little lower.Let me know your thoughts
BTLFEDSS
Old Jun 15, 2007 | 09:27 PM
Almostryan3's Avatar
Its not bad, not great, but the weather might of had an effect on you. With a 150 shot stall 3.73s and ET streets my car went 7.0 1/8th mile, was never sprayed at the 1/4
Old Jun 16, 2007 | 08:30 AM
BTLFEDSS's Avatar
Anyone any advice,Blew the 10 bolt up on the last pass
BTLFEDSS
Old Jun 16, 2007 | 01:44 PM
BAIN's Avatar
When I was SI the best I ran on a 100 shot was a 7.0 1/8 and 1.49 60' with bolt-on's, 26" QTP, 3.23's, and a TCI 3500 stall. I think some 3.73 gears and a 3800 stall would make a world of difference.
Old Jun 16, 2007 | 05:17 PM
chrs1313's Avatar
i see you have a cam in the sig but didn't list it in the mods...that is why i got confused to why you had your window switch at 6600...what cam do you have
Old Jun 16, 2007 | 07:16 PM
darrensls1's Avatar
You need a bigger converter. 3600-4000 with a hard hitting STR would make a world of difference IMO.
Old Jun 16, 2007 | 11:13 PM
BTLFEDSS's Avatar
ASA Cam but i'm also spraying through shifts
BTLFEDSS
Old Jun 17, 2007 | 12:37 PM
Navy David SS's Avatar
OK the stocker is dead. Are you going with a 9" or 12 bolt? If so just go with the 9" - IMO better gear selection (I have had both).
Before you decide on gears and tires, you'll need to know your HP. What RPM are you trapping at now?
I like it big!!! Bigger tires: 28"+; bigger stall: 4200; bigger gears: 4.10+
But again you'll need to decide on goals - 9's? 10's? You have the tranny (I assume you launch on trans-brake). You will want to leave a little room to up the shot from 100 to say 150 or 200.
My recommendation?: 9" with 4.10's (or even 4.30's) with 28x10.5x15 with a 4200 stall -- been there ran low 10's on stock bottom end.
Good luck
David
Old Jun 20, 2007 | 10:21 AM
BADSZ28's Avatar
I think that cam would not be too nitrous friendly. 4.10s may be too much. You would have to rev it to high hell once you start going faster. 3.73s or 3.90s seam to work well on autos with N2O. I would go higher on the stall. What HP rating is that stall too at that stall speed? When shopping for A3 stalls, most manufacturers seam to rate them at 400hp so you may be ok. That DA is real high. You would have to compare an NA run with a N2O run at the same DA to see what you really gained.
Old Jun 21, 2007 | 10:29 PM
BTLFEDSS's Avatar
Car made 321/323 Na and 431/430 on a 100 shot.I am going to send my converter back and have it restalled to 4000/nitrous converter.Not sure what iam going to do about gears and tires
BTLFEDSS
Old Jun 22, 2007 | 05:02 AM
Duffster's Avatar
Surprised no one said it, but "DAYUM, thats consistant!"
Nice ones!
Old Jun 22, 2007 | 09:25 AM
BADSZ28's Avatar
You should pick up quite a bit with that. You may want to wait on the gears to see how the verter does. Also keep in mind, the more you pill it, the higher the verter will flash. Are you spraying out of the hole? Judging by your times your verter is very tight. You are trapping M6 mph for the ET.
Old Jun 22, 2007 | 02:41 PM
BTLFEDSS's Avatar
I was flashing the converter from 1200 and the window switch is set at 3000.I'll try to get up a video,my mph was off from what i thought it would be maybe because of the weater?Last year with the M6 and Hot Cam and a 125 shot i went 11.6@122 with a 1.9 60' and was trapping 112 on the motor.This year my mph is a bout the same on the motor 111-113
BTLFEDSS
Old Jun 22, 2007 | 02:49 PM
waterbug1999's Avatar
Spray that bitch out of the hole and hold on.. I did that the 1st time a month ago and and it threw my head back like a ****... I am surprised the 10 bolt held together.
Old Jun 22, 2007 | 03:00 PM
BTLFEDSS's Avatar
http://vids.myspace.com/index.cfm?fu...oid=2034260185
Here the video
BTLFEDSS
Old Jun 22, 2007 | 03:04 PM
BADSZ28's Avatar
Don't be affraid to hit it out of the hole. You would be surprised the effect on the 60' from the hole and from a few feet out. If your track sucks for prep, then don't even bother spraying it. Just a waste of N2O and gas if you ask me.
Old Jun 22, 2007 | 04:34 PM
tektrans's Avatar
Seems about right for the mods and weather. Very consistent, nice work!
Old Jun 22, 2007 | 04:48 PM
blownws6_nc's Avatar
u got some cool videos............
Old Jun 22, 2007 | 10:05 PM
BTLFEDSS's Avatar
Just want to get down to the 10.90-10.70 range.Think the the restall will get me closer??
BTLFEDSS
Old Jun 23, 2007 | 10:53 AM
BADSZ28's Avatar
Originally Posted by BTLFEDSS
That was weak. The restall and hittign out of the hole will help. Sounds like you are hooing so as long as the suspension is there you should rock the track.
