new best
Old Jul 21, 2007 | 12:18 AM
01BlackCamaroSS's Avatar
Default new best
I ran at the track tonight and got a new best time a 12.13 at 109mph and a 12.17 at 111.9mph, my 60ft were identical at 1.75, i really think that i can break into 11's if i can get traction in the 60ft
Old Jul 21, 2007 | 04:20 AM
Mac 2002 SS's Avatar
congrats on the new best !! what rpm are you shifting at with that cam ?
Old Jul 21, 2007 | 10:17 AM
i jsut put it in drive and let the car shift for me, my tune is crappy it has me shifting at 5800 rpms
Old Jul 21, 2007 | 02:25 PM
OMG !! Man, I know you must know someone up that way who tunes LS1's ??!! You should be shifting around 6300-6400 easy with that cam .There are alot of guys in Maryland who are apart of Eastern F-Body Association who tune cars all the time. Here a link and maybe there is someone close to you that can help you out. Good luck !!
http://www.easternfbody.com/forum/index.php
I bet once your car is tuned ,you should be able to run 11.7's or better easy .
Old Jul 21, 2007 | 09:31 PM
thats what i was thinking, i got it tuned in glen burnie but the reason my shift pionts r so low is because i had the car tuned then took it back bc i was hiting the rev limiter on the shift from 2-3 so i went back and he droped the rpms back then found out that the trans was messed up so i instaleld a trans but never got the shift points readjusted
Old Jul 22, 2007 | 04:15 AM
your rev-limiter is probably set to low or you were spinning and your car shifts so quick causing you to hit the rev-limiter. do you know where your rev-limiter is set ? You might want to try this with this when you do get it tune......1-2 shifts 6300/ 2-3 shift 6300 / 3-4 shift 6300 . As for your rev-limiter ,set that at 6700 on all shifts. One thing about an A4 car ,you don't have to rpm the **** out of it . hopefully someone up that way has a hp tuner or something to help you out ,man. I know your car will be running great once the bugs are worked out .
Old Jul 22, 2007 | 07:03 PM
AshWS6's Avatar
hey dustin, its jeff- saw u at the track the other day when we were there with ash's car, give me a shout so we can get those shift points adjusted!!
Old Jul 25, 2007 | 10:57 PM
hey jeff whast going on buddy will do me and a buddy of mine are actually abuot to put on some 5.3 heads on my car this weekend, do you think i could bring the car by and get it tuned afterwards
