Hit the 9's, N/A pump gas (with L92 heads).
Old 07-24-2008, 01:55 AM
  #61
BLWN1's Avatar
badassss
Old 07-24-2008, 06:52 PM
  #62
1cdub's Avatar
Originally Posted by 00BlackSS
whats the distributor and water pump u running?
MSD billet 302 ford distributor, its the only one that will work with the GM dist. drive front cover conversion, water pump is Mezeire drag with spacers to push it out past the thicker front cover..
Old 07-24-2008, 06:55 PM
  #63
1cdub's Avatar
Originally Posted by freedom_fighter
you coming off the footbrake or transbrake? what size stall are you running? Have a VERY similar setup below and this got me quite excited :-)
all passes are off the footbrake and I'm currently running a TCI 4200 stall.....but, with my relatively heavy car and the torque of the 454 its stalling at about 5100.
Old 07-24-2008, 07:02 PM
  #64
1cdub's Avatar
Bringing this one back up, are the tires tucked in, what wheel/backspace are you running, is the rear narrowed?
JSJ, no minitubs, just a S60 rear narrowed 2" on each side...wheels are Weld Magnums 15x8's with 3.5" backspacing. Lots and lots of the BFH mod is all that is needed...oh and lil trimming of the rear fascia down low.
Old 07-24-2008, 07:40 PM
  #65
TJ
TJ's Avatar
i didnt think to ask this before, but what CNC heads are you running and what valves are in that bad boy?
looks killer with the magnums.
Old 07-24-2008, 08:37 PM
  #66
1cdub's Avatar
thanks TJ, yeah I'm diggin' the new Magnums, I never really liked the draglites but they were on the car when I got it....soon as I had the car running what I wanted, the wheels were the next purchase.
As far as the heads, they are outta the box CNC'd L92's from www.sdpc.com with manley valves.
Old 07-24-2008, 09:36 PM
  #67
69_YENKO's Avatar
awesome car man!
Old 07-27-2008, 09:53 AM
  #68
00BlackSS's Avatar
thanks man! looking to go into this swap, try to do some research now to see everything id need to do. such as what for running the power windows and what not.
Old 07-27-2008, 11:13 AM
  #69
BAKED's Avatar
Sick ride man.
Old 07-27-2008, 01:16 PM
  #70
skidmarkSS's Avatar
PM sent
Old 08-19-2008, 11:46 PM
  #71
Qwiknotch's Avatar
you ever dyno it? engine or chassis?
curious because my engine is about to be dyno'd and my car will weigh 3200lbs
Old 08-20-2008, 07:09 PM
  #72
cncbird's Avatar
What rear suspension are you running?
Old 08-21-2008, 09:51 AM
  #73
DASHTI's Avatar
Default intake
Congrats!
What intake manifold is that?
Old 08-21-2008, 11:21 AM
  #74
tektrans's Avatar
there's only one carb style intake that fits those heads.
http://www.sdparts.com/product/25534...arburetor.aspx
Old 08-21-2008, 11:57 PM
  #75
1cdub's Avatar
no dyno for me...only track times...
Old 08-22-2008, 12:00 AM
  #76
1cdub's Avatar
BMR Extreme for the T/A, LCA's, and panhard
stock 99' shocks and springs
Old 08-22-2008, 03:13 PM
  #77
gator's 99TA's Avatar
stock shocks and springs with a heavy *** LSX block....
and guys bitch about not getting weight distribution with fancy DA Strange/QA1 shocks and springs on aluminum blocks
awesome job CW.
Quick Reply: Hit the 9's, N/A pump gas (with L92 heads).
