is there a stock shortblock record??
Old Apr 27, 2008 | 02:23 AM
RDTA's Avatar
Default is there a stock shortblock record??
I was just wondering if so what it was. we just took a new setup out and layed down a pretty decent 1/8th number. stock 05 6.0 shortblock, stock l92 heads, crane cam, victor style intake, and alittle boost. it was not in a f body but a s10.
it went 5.82 @ 120 in 1/8th @ 10lbs boost
Old Apr 27, 2008 | 05:21 AM
Gimp98TNT's Avatar
damn man, those are some stout #'s for sure. I think the record for stock suspension f-body is around 6.0 in the 1/8.
What does ur S-10 weigh?
Old Apr 27, 2008 | 08:49 AM
RDTA's Avatar
3255. had to be 3200 for ez street class we was running. and on a 275-60 dr
Old Apr 27, 2008 | 01:43 PM
Frank02L's Avatar
3265 with me and ice in it. 1.36 60' on the 5.82@119.52 pass. It did go 1.35 the next pass but after I put it in high gear it banged like it was lean. I think now somehow the two step was engaged. "Stock suspension" truck.
Old Apr 27, 2008 | 10:09 PM
RDTA's Avatar
I seen parish went 6.11 in the 1/8th with the car he built. it was a stock long block right? other than that, i havent found much.
Old Apr 27, 2008 | 11:37 PM
daniel6718's Avatar
stock longblock with power adder is i think a 9.70
Old Apr 28, 2008 | 10:45 AM
Frank02L's Avatar
I think that car had a LS6 cam in it but otherwise basically stock.
Old Apr 29, 2008 | 09:15 PM
dman's Avatar
holy hell, i've got a stock 2005 6.0L LQ9 motor with a Z06 cam with twin T70's in the making. would love to acheive those numbers. what cam specs if you don't mind me asking.
Old Apr 29, 2008 | 09:18 PM
RDTA's Avatar
yep. this was the second weekend out with it.
its a crane 236/240 600/600 on 112
my old cam i run in my ta
Old Apr 30, 2008 | 07:38 AM
Frank02L's Avatar
dman... You should recognize alot of stuff off this truck As a matter of fact I just ordered a meziere h2o pump for it monday. Also Brian built a twin MPT70 408 and it went 118 in the 1/8th footbrake launched.
Old Apr 30, 2008 | 10:07 AM
GS WS6's Avatar
There is a stock longblock 6.0 motor camaro in Dallas that probably holds the record.......
Old Apr 30, 2008 | 10:11 AM
Frank02L's Avatar
Do you have any more info about it? Just curious thats all.
Old Apr 30, 2008 | 10:22 AM
GS WS6's Avatar
Stock 05 escalade longblock, LS6 intake, 250-300 dry shot, 3300lbs raceweight, TH-350, 9"
1.302 60' off the footbrake, on 325 MT DR's
I would would rather not post an ET, the car runs for money.
Old Apr 30, 2008 | 10:27 AM
dman's Avatar
RDTA - pretty healthy cam compared to my Z06 cam. But damn that thing flies..
Frank02L - hey man, i didn't realize this was the truck your involved in. Is it the Isuzu? The pump is enroute to you as we speak. This truck has me chompin' at the bit to get my bucket running. And I was afraid this engine wasn't strong enough to put my 3200# stang into the 9's..... hahaha. Oh, do you know what exhaust housings he's running on the twin MP T70's? i realize it's got more cubic inch than my little 6.0 but i'm getting .58 housings for mine. I want quick spool-up and a tight converter
Old Apr 30, 2008 | 10:32 AM
RDTA's Avatar
everything i have done has a big cam in it. lol I have one with a texas giant in it and twin 70's. its hauling ***, only been on the track twice. and has the cars class MPH record. off foot brake. I dont see why u would have any problems running in the 9's.
oh the ex housings are .68's I think. lol they was my old turbos, but i cant remember for sure. i had them on a 12.1 355 sbc.
Old Apr 30, 2008 | 12:34 PM
Frank02L's Avatar
Darin, Yeah I'm in charge of parts getting here and Brian (RDTA) has done quite a bit of the labor. The truck is 3265 and I wouldnt worry about going 9s. Should be pretty simple. The cam won't make that big of a difference, I mean so what if its 50-100hp difference. You'll still be able to make your goal of running 9s, and you can turn the boost up a little to make up the camshaft difference.
Old Apr 30, 2008 | 01:14 PM
dman's Avatar
RDTA - thanks for the info, my .58's will most likely suite me well for my goals. Also since the motor is stock my compression is 10:1 from the factory. I'm real excited about experimenting with high comp and boost. Most i ever worked with was 9.7:1 and it was fine. Also i'm planning on running E85 so i think the comp will be fine.
Frank - next time you order make a note when checking out and i'll adjust the discount you guys are getting on stuff. My brain is overfull so the chance of me remembering is slim to none. Good luck with that truck and keep us informed.
Old Apr 30, 2008 | 01:37 PM
sdbrown84's Avatar
If you are talking stock longblock with no boost or any power adder, I think someone on these boards went deep into the 11's by just doing proper suspension mods. IMOP stock long-block means no power adder or otherwise, just old fashioned muscle.
Old Apr 30, 2008 | 01:39 PM
RDTA's Avatar
I agree. I was just wondering on both. I read through some of the time archives.
Old Apr 30, 2008 | 01:43 PM
dman's Avatar
i think the thread is aimed more at how strong these engines are. so i would think FI or Nitrous would have to be present to push the power envelope
Darin
