13.6 at 107 Wtf?
Old Jul 17, 2008 | 03:47 PM
z28_YOU_HO's Avatar
Good mph just work on that launch!
Old Jul 17, 2008 | 03:59 PM
Jersey_TA's Avatar
You'll drop .4 just by going in sub 50 degree temps.
Old Jul 17, 2008 | 05:23 PM
MMMZ/28's Avatar
Looked at the slips here
RT.363
60-2.324
330-6.086
1/8-9.044 83.72
1000-11.560
1/4-13.619 - 107.09
Old Jul 17, 2008 | 06:05 PM
s346k's Avatar
when soaking up randy's advice, bear in mind that ss he had went 13.1 in the 1/4 with headers and a tune and a few bmr susp. upgrades as well as drag radials. launching the cars will be totally different, as his car bogged from almost any rpm under 3500 it seemed. but, the ta went 13.2 with a lid and slowmaster, every car is different. i've seen better results shifting ~5500. riding out the gears produced the same 1/8 mph, but killed my 1/4 trap 3-4 mph every time.
Old Jul 17, 2008 | 09:29 PM
MMMZ/28's Avatar
Lol My feeling is that If I shift 3rd ar 5200-5400 I will do better but I will try both sides just to appease ppl, they are trying to get me to put some DR's on it but I think I want more runs on street tires just to see what I can do
Old Jul 18, 2008 | 06:01 AM
ruthusk8r's Avatar
yeah, same thing here, went to the track on Wednesday, ran consistent 13.4s-13.5s at 107-108. I'm running on stock crappy street tires spinning off line each time from about 2600-3000. 60s were from 2.2-2.4..... lowest was 2.19. I thought i could get down to low 13s maybe a high 12 with mods in sig, but i guess not with my tires
You do have a good trap though
Old Jul 18, 2008 | 06:56 AM
PowershifterNC's Avatar
why would you ever short shift if you're wanting the best time? I'd shift @ 5800 minimum. You're not even reaching the top of your powerband @ 54 which throws you too low in 4th.
Old Jul 18, 2008 | 07:05 AM
s346k's Avatar
go ask the guys trapping 112+ with exhaust where they shift..
Old Jul 18, 2008 | 07:52 AM
svtwhat?'s Avatar
surely not 5200rmp.... I can see 5800, but the earlier you shift out of 3rd, the lower in the range you are in 4th.... and then you have all the time it took to shift.
Old Jul 18, 2008 | 09:15 AM
exactly my point...sounds like the guys trapping 112 are feeding you some bull
Old Jul 18, 2008 | 09:24 AM
MMMZ/28's Avatar
I mean TQ comes into play too guys.......
Old Jul 18, 2008 | 10:43 AM
  #32
s346k's Avatar
exactly. look at the tq curve on a stock cam car. most of the "fast" bolton cars are shifting between 5,400-5,700. hp is not carrying the cars down the track, that is evident as the tq curve is forever long and flat, where as the hp curve basically sucks.
Old Jul 18, 2008 | 11:08 AM
  #33
54-57 is much better than 52..atleast you've hit peak power somewhere in there
Old Jul 18, 2008 | 11:20 AM
  #34
MMMZ/28's Avatar
We shall see
Old Jul 18, 2008 | 12:29 PM
  #35
s346k's Avatar
i disagree. i had an a4 big stall car that trapped 110 hittin the rev limiter hard on 2-3, i can see the same car with an m6 easily going 112 if not faster, as i don't feel the shift points were optimal on that a4 setup.
Old Jul 18, 2008 | 01:11 PM
  #36
huh>? what does that have to do with what I said
1st off hitting the rev limiter won't net you any speed/time
2nd you want to stay where the peak power is, torque is not going to start dropping dramatically until after peak power
Old Jul 18, 2008 | 02:06 PM
  #37
LIL SS's Avatar
Moderator
My advice, get tires, slip the clutch at 3,500 just enough to leave hard and not induce tire spin.
On DR's with 335rhp I've gone 12.44@112.9 at full weight.
Bone stock including tires, 13.1@106.
This was in my 01 SS that is long gone.
Old Jul 18, 2008 | 03:29 PM
  #38
Kingc8r's Avatar
Get that 60ft down to a 2.0-1.9 and you'll be at 13.0s to a possible high 12
Old Jul 18, 2008 | 04:25 PM
  #39
MMMZ/28's Avatar
I'm gonna run this bitch on a 1/8 of a tank next time....12's hahah
Old Jul 19, 2008 | 07:56 AM
  #40
svtwhat?'s Avatar
I'm gonna spray on this bitch on a 1/8 of a tank next time....12's hahah
hopefully
