few 100 shot passes
few 100 shot passes
weather was THE WORST ive ever raced in. it was bad.
motor pull was only 7.03 at 97.82..... it felt so slow i thought some plug wires were off.
1st pass on the spray was 6.76 at 105, with a horrible 1.62 60ft.
6.64 at 104, 6.59 at 105, still with only a 1.53 60ft. motor it does 1.50's so i adjusted the shocks on full looose front and rear, and took out about a 1/2 pound of fuel pressure out.
1.402 60ft
4.192
6.095
6.522
105.38 mph
275/60 hoosier DR's through the catback!
talk about fast..... car was in the air.
with a better track, i dunno what its gonna do on a 150..... not to mention cooler weather.
1.402 60ft
4.192
6.095
6.522
105.38 mph
That's hookin and bookin! I finally went 1.41 my first time and it's a ride.. You're looking at low low 10's...it should be a monster with just a 150 shot.
Min'e also an IROC on the hose...pic here of the 1.45 I pulled..on my way to a 10.15 pass. http://www.photoreflect.com/pr3/orde...HA010044&po=44
i just tossed the 100 in to make sure the rod bolts know whats comming.
maybe they will work out in the off time and buff up so it will stay together on a 150.
i dont wanna push it too bad.
plugs in the motor look good, and the a/f was a SOILD 11.40... the numbers didnt move all of high gear down the track. i might take another 1/2 pd of fuel pressure out next time out. i think its got more left in it the way it sits.
Sweet deal tj! Some cooler weather and 150 shot lookout!!!!!!! not bad for a mid size cam and some patriot heads on a stock 6.0 block here is a pic i have of the car
