Cam only trap speeds
#46
#not my car. Its a member car on here that he sold awhile back but it was a nice setup.
HPE S cam (238/240 on 112lsa)
Patriot gold dual springs with titanium retainers
TSP 7.400 pushrods
Melling HV oil pump
LS2 timing chain
LS6 intake
Hooker ceramic coated long tubes
TSP (New version) ORY y-pipe with an DMH Electric cutout into a stock SLP Dual Dual catback 160 thermostat
SLP lid
42lb delphi injectors
Steel shift forks with bronze pads
3.91 gears
11.766 at 122.79 mph on 18 inch vette wheels. No weight reduction. Also car had a stealth speaker sub deal going on. Impressive in my book.
TSP 7.400 pushrods
Melling HV oil pump
LS2 timing chain
LS6 intake
SLP lid
3.91 gears
#47
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Edit: anyone on here running the True duals is trapping noticeably higher than the guys running a Y pipe set up.
#57
119 with stock cam lol stock internal car no power adder, can run at least 113 mph in 3500 da 90 in the 1/8th and 95mph in the 1/8th, looking for at least 5 more mph if I put a cam in.
#58
So with the right cam and supporting mods I bet you can find about 8mph.
#59
Thanks for the info gives me hope for running close to 10.0x's cam only.
#60
I'll have at least 2 more mph from doing full front suspension and front and rear drag brakes and lowering my iat's from what they were. Transmission is faceplated now so I might run a little quicker in the same form as I did the 119. The other trans took longer to shift and could not stay wot shifting.
