What will my 10.5 inch tire camaro run in the quartermile? Specs/Pictures..
Here are the 1/8th mile times..
Range from 6.40-6.50's
Mph 108-112..
60' foot times are 1.40-150's best has been 1.36 60..
Im wondering what the car will run in the quater mile.. im taking it out this friday- hopefully ill make some shake down passes- and i might be able to get a full pass..
364 ci - 9pounds of boost vortech
Ford 9inch with 4.10 gears 35 spline axles..
Tire is a 28x12.5x15 tire..
Transmission has a 4000stall flashes around there.. has 3 step.
Turbo 400 trans..
What do you guys think is will/ or should run?? Let me know.. Et / mph.. thanks- Aj
![](http://i287.photobucket.com/albums/ll142/Bigblock4-speed/84%20z-28/CampbellandCars054.jpg)
![](http://i287.photobucket.com/albums/ll142/Bigblock4-speed/84%20z-28/CampbellandCars058.jpg)
![](http://i287.photobucket.com/albums/ll142/Bigblock4-speed/84%20z-28/CampbellandCars062.jpg)
Mph 108-112..
Turbo 400 trans..
![](http://i287.photobucket.com/albums/ll142/Bigblock4-speed/84%20z-28/843.jpg)
