Drag Racing Tech
Instant Center
Old Oct 17, 2008 | 01:31 AM
02 BLK WS6's Avatar
Default Instant Center
By adjusting the angle of the LCA and the torque arm determines the instant center, right? Take the angle of the LCA and the TQ arm. Overlap them, and where they intersect determines your instant center? Draw 2 straight lines, one being the LCA and the other the tq arm, one at a slight angle, where they intersect is IC. My car squats too much right now. In essance, since my tq arm is adjustable, I can shorten it to raise the front so the mount is parallel instead of slightly forward and that would produce anti-squat. Any input would be appreciated. I think that I am understanding this the more that I read. It is a bit confusing.
Thanks
Old Oct 17, 2008 | 08:00 AM
96LT1355Z28's Avatar
PM Sent!
Old Oct 17, 2008 | 08:12 AM
mad_steve's Avatar
what kind of torque arm do you have?
Old Oct 17, 2008 | 10:28 AM
02 BLK WS6's Avatar
Spohn tunnel mount
Old Oct 17, 2008 | 12:42 PM
Nimitz87's Avatar
subscribing...always trying to understand this.
Chad
Old Oct 17, 2008 | 01:35 PM
dlove's Avatar
https://ls1tech.com/forums/advanced-engineering-tech/396309-instant-center.html
Old Oct 17, 2008 | 02:04 PM
mad_steve's Avatar
thanks dlove
Old Oct 17, 2008 | 07:06 PM
02 BLK WS6's Avatar
I've read the thread to the end. I was seeing if the way that I interpreted it was correct. Is my interpretation correct? I'm pretty sure that it is. Call me a retard if you want.
Old Oct 18, 2008 | 08:36 AM
mad_steve's Avatar
RETARD! no just kiddin. You seem to have it down pretty straight.
Old Oct 18, 2008 | 10:58 AM
02 BLK WS6's Avatar
Thanks
Old Oct 18, 2008 | 06:15 PM
DMH Fabrication's Avatar
So which way is the correct way to find the IC with a slider on the front of the torque arm?
There are two ways listed in the thread that is linked above. One says you use a line perpendicular to front torque arm mounting point w/ the lca line. The other way says to use a line drawn from the center of the rear torque arm mounting points to the front torque arm mounting point w/ the lca line.
