Drag Racing Tech
Tire Pressure MT ET Streets
Old Oct 20, 2008 | 12:29 PM
Prerun4fun13's Avatar
Default Tire Pressure MT ET Streets
Ok i have a set of MT ET Streets 26x11.5x16 I was wondering what tire pressure i should start with at the track?? Oh ya and its a M6. Also if you can give me an estimate of what time i will run that would be nice to.
I ran a 12.9@113 with a 2.2 60ft on street tires.
My mods are
LS6 Intake
SLP Lid
MS3
Pacesetter LTs
3" to 4" merge
4" E cutout
magnaflow CB
Centerforce Clutch
Stock 10 Bolt 3.42 Gears
****I know my 10 bolt is on bought time please do not come here to tell me that u post ******!!!!!*******
Old Oct 20, 2008 | 12:48 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
A good starting point is 16lbs. If it bogs the car down add a little pressure.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Oct 20, 2008 | 06:57 PM
speedshifterNC's Avatar
I usually start at 16 as well. My best pass has been on 14 though
Old Oct 21, 2008 | 12:16 AM
Ok i started them at 25psi and i launched on the street and they hooked after 20ft with a 4k slip.... BUMP
Old Oct 21, 2008 | 12:31 AM
xpndbl3's Avatar
25 is WAY too high, shoot for 16 then drop them by .5 pound until they stop getting you a better 60' time
Old Oct 21, 2008 | 01:57 AM
96LT1355Z28's Avatar
Mine likes 12-13 psi. at the track, I run 18 on the street.
Old Oct 21, 2008 | 10:39 AM
12secSS's Avatar
If you have a compact air compressor with you at the track, then start at 16-18 PSI and go lower. If no improvement, try adding air. I usually would start at 24 PSI, since I did not carry a compact air compressor, and drop the pressure from there. I noticed my best 60' on my setup was around 18-20 PSI. Each setup will vary, but now you have a decent starting point for pressure.
Old Oct 21, 2008 | 10:58 AM
ok thanks guys!! I am gonna start at 25 just because i dont have a portable compressor.
Old Oct 21, 2008 | 01:18 PM
PowershifterNC's Avatar
waste on time on mt drs...you should atleast start at 18
Old Oct 22, 2008 | 03:10 PM
1CAMWNDR's Avatar
Are these Drag Radials or the bias ply cheater slicks?
Old Oct 22, 2008 | 03:30 PM
showoff's Avatar
by the way he described them they sound like the bias ply et streets...i usually start mine at 13.5 cold after the burnout its around 15psi, i normally cut 1.4x 60's all day long
Old Oct 22, 2008 | 03:49 PM
lemons12's Avatar
i start at 14 with mine..
Old Oct 22, 2008 | 06:50 PM
TA1364's Avatar
Start around 15-16. I have had them down to 11 and didnt like the way it felt going down the track. 14 seems to be the best for me, went 1.58 60'.
I know some have mentioned since the bias ply is not as stiff as a street radial I would loose mph. I have ran both and noticed no difference in mph.
Old Oct 22, 2008 | 07:08 PM
lemons12's Avatar
the lower psi you go the more mph you lose.. the high the psi (or more spinning) the higher your mph but lower e/t.
Old Oct 22, 2008 | 08:14 PM
danhr's Avatar
with 25 psi, your contact patch was probably only 1/4 of your entire tire.
like everyone said, start with 16 and work your way down.
I usually run 8 in mine
Old Oct 23, 2008 | 02:05 AM
Thanks guys!!!
Old Oct 24, 2008 | 07:52 AM
06black6spd's Avatar
Ya I have heard alot of guys running at 14-16 on them and you should get your 60' down to a high 1.7 or low 1.8x that should result in a 4-6 tenths drop overall
Old Oct 24, 2008 | 09:43 PM
SidewayzOZ's Avatar
I run mine around 12-14. Starting at 16 is definitely a good idea as others have said.
Old Oct 25, 2008 | 06:19 AM
jp74's Avatar
My best times are with 19 psi.
Old Oct 25, 2008 | 07:19 AM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
I run mine at 13.5
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
