Drag Racing Tech
Best alignment specs for drag racing?
Old Sep 14, 2003 | 09:12 PM
quickWS6's Avatar
Default Best alignment specs for drag racing?
What are the best alignment specs for drag racing? I am mainly looking for how to keep the car going straight.
Old Sep 15, 2003 | 07:56 AM
MADMAN's Avatar
LS1Tech Sponsor
Default Re: Best alignment specs for drag racing?
You will need as much caster as you can get. If you have aftermarket control arms then you should get around 5-6 degrees negative. Set the camber at 0. On toe never have toe out. Set your toe at 1/16 in on both sides. Then raise the front of the car till the tires barely touch, then reset toe at 1/16 in. Set the car down and recheck.
__________________
www.madmanandcoracing.com
225-343-9029
