Drag Racing Tech
10 pt roll cage ?'s
Old Oct 21, 2008 | 11:08 AM
veee8's Avatar
Default 10 pt roll cage ?'s
I have installed most of the 10 point cage in my car, my question is, where to put the 2 little bars that go from the main hoop down to the frame or subframe connectors? Obviously we don't have frames, and the SFC's are nowhere near close to being able to be tied in that way? Do I put 2 more 6x6 plates on the floor in the back seat area? Or to the trans tunnel with plates? Pics would be great.
Assuming it is installed correctly, what e.t. is a 10 point good to?
What else do I need for a proper cert?
Window net, 5 point harness, Drive shaft loop, SFI flexplate, wheels studs, fire jacket, helmet, parachute.
Anything else? Looking to be legal to 8.50's
Old Oct 21, 2008 | 11:34 AM
JL ws-6's Avatar
Race your car!
I put those bars right where the rear seat brackets were, and welded a plate to the floor there.
Old Oct 21, 2008 | 11:37 AM
JL ws-6's Avatar
Race your car!
You will also need a tranny scattershield or a SFI approved case (dedenbar glide case) License, battery shutoff, you won't need the chute unless you've roing over 150 mph, you will need gloves, shoes aren't required but are a good idea, if I can think of anything else I will post it up.
Oh, nhra lic too.
Old Oct 21, 2008 | 11:53 AM
veee8's Avatar
I was thinking of that, did you just drill out the welds for the factory brackets, then just weld the 6x6 plates there?
The scattershield might be a PITA, what are guys using, TH400?
Old Oct 21, 2008 | 12:00 PM
BadBoo79's Avatar
My Alston cage is done with plates to the trans tunnel and the "kicker" bars run there.
For the transmission, I have a 400 with a JW Ultrabell (replaces flexplate shield) and an RCI trans blanket.
Old Oct 21, 2008 | 12:43 PM
JL ws-6's Avatar
Race your car!
CSR th400 shield, it fits no problem, tight but it fits.
I just cut the metal off where it came up off the floor, ther'es probably 4 oz of them left. An air chisel would probably pop the welds right off.
Old Oct 21, 2008 | 01:40 PM
veee8's Avatar
Anyone have any pics of the cages?
What kind of labor is involved with installing an Ultrabell?
Old Oct 21, 2008 | 01:51 PM
ty_ty13's Avatar
7 Second Club
https://ls1tech.com/forums/drag-racing-tech/926863-2002-camaro-build-up.html
youll see there... i have a 12 point but its close enough...
Old Oct 21, 2008 | 03:53 PM
veee8's Avatar
Thanks, I think I will put the bars there.
Does anyone know where the 10 pt. will take me? 8.50's?
Old Oct 21, 2008 | 03:54 PM
ty_ty13's Avatar
7 Second Club
yeah 8.50 is where youll be same as me...
Old Oct 21, 2008 | 07:34 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Cage will be good to 8.50 when certified with window net.
Derek
