Please critique my launch technique
i'd really like to get my 60' down further. i fill the tires to 18psi. i've tried various burnout times from a quick couple spins to get the sand off, to a full blown smoke show, and have seen no difference. launch is basically tach it up to 5-6k and dump the clutch and gunning it.
my staging technique could use some work as well. at the tracks around here, the moment both cars get the 2nd stage light, they hit the button. i can never get ready and comfortable and get my rpms to where i want them, so i'm not even sure how various launch rpms are affecting things.
my shift light is set to 6k, hoping for a 6200rpm shift. i do let off the gas when shifting, cuz i dont want to kill my tranny.
details on the car:
bolt-on's and a tune, putting down about 360rwhp before i got the 12bolt. has a textrailia clone clutch, pro 5.0 shifter. suspension/chassis mods are: SFC, LCA, PHB, TA, DSL, STB, poly sway bar bushings. i havent had my LCA brackets welded on yet.
vehicle weight after the 12-bolt is 3755 with me in it, and a full tank of gas. i have the rear seats removed, and pretty much all the emissions equipment removed.
But what does the car do when you dump it? Spin or bog? With ET streets I'd try and lower the tire pressure down to say 15psi and give it a go. Those are basically a slick with grooves cut in contact area.
-Mark
-Mark
how exactly does that 2-step work? is it like a rev limiter to let you floor it and not have to try to hold the rpms?
You car sounds almost the same as mine used to as far as the setup goes. Have you tried adjusting your pinion angle? -2 doesnt always work perfect for all cars, mine is set at -2.5 if i remember right. I ran 26-10.50-16 ET's Streets and was cutting 1.77-1.85 60's, played with the torque arm a bit and also the launch and got it to very consistent 1.61-1.63's.
I usually hold at 5300 RPM and when I see the last light I mash the gas and almost immediatly dump the clutch. It usually works out perfectly that I see a quick flash of the shift light and im off like a bandit....... I usually kept it in the 12.1-low 12.2 range.
i do still have a set of LCA brackets that i need to have welded on. dumbass me thought that i could take my bolt-on ones from my 10 bolt and bolt them to the 12 bolt... now i wish i ordered the 12 bolt with them already welded on
when i launched at 4000-4500 it really bogged. my theory for launching at 5000-6000 was that when the clutch engaged, it would drop to aroudn the 4500 point. but honestly, i dont really stare at the tach when i drive (thats what the shift light is for!), so i think i'll have to get a data logger too.
