Improvement, take a look?
60' 1.905
330 4.958
MPH 75.44
1/8 7.438
MPH 97.28
3:22PM Nov. 2 2008
temp was in the low 80's
car is basically a 76mm turbo on stock engine, tranny has a 3400 stall, and rear is the stock 10 bolt with 2.73's
run was on some M/T ET Street tires with a TINY burnout. tires were at 18 PSI
took off at about 1900 RPM's
suspension includes LCA relo brackets and BMR LCA/PHB
car is full weight, still with AC and stereo
was wondering if those numbers look correct, to each other. also any tips on launching it? seems like the car has more in it just cant get it to launch correctly. Advice?
thanks for looking!
like i said it's just a turbo'd stock driveline camaro with a stall lol, i'm going to see what i can flash it at on sunday. like i said i know the car has more in it it's just the take off that's so lazy my next mods are going to be the th400 tranny and the 9inch rear, then the new block on about 17 psi
for now i just want to see how far i can get the stock driveline to go lol kinda like the guys on the FI section seeing how far they can push a stock lq9 block, so far i belive it's 850 hp on stock internals
Also, try only a 1/4 tank of gas, then fill up at the corner before you go home. Just giving you some tips from a pro! Last edited by fasttagurl; Nov 7, 2008 at 12:39 PM. Reason: forgot a word
