Drag Racing Tech
!!!more Weight Reduction
Old Nov 4, 2008 | 01:03 AM
nemss1's Avatar
Exclamation !!!more Weight Reduction
removing fog lights/brackets and horn tomorrow!
removing ABS/TCS later (as soon as i purchase the abs delete block and non-tcs throttle cable)
Old Nov 4, 2008 | 01:09 AM
94'BLKBRD's Avatar
Awesome......
Let me be the first to say......what's the point of this thread?
Old Nov 4, 2008 | 02:56 AM
nemss1's Avatar
Originally Posted by 94'BLKBRD
Awesome......
just the excitement haha
Old Nov 4, 2008 | 07:23 AM
trigger1's Avatar
It's a good time tearing crap out of the car.......
Old Nov 4, 2008 | 08:04 AM
Magnet's Avatar
so what have ya done so far? What your raceweight? Regret taking anything out?
Old Nov 4, 2008 | 10:15 PM
nemss1's Avatar
haha yes its always fun to rip things off of the car
Old Nov 4, 2008 | 10:19 PM
98TADRIVER's Avatar
nice, ive taken a few things out. some things i put back when its too warm to race
spare tire and jack
rear seat
air bags
bumper supports
catback replaced with a single straight pipe
a/c is out for winter/early spring
carpet, sound deadening and most of the interior including front pass seat comes out soon
probably going with a lighter battery
theres probably more, but i cant think of it all
Old Nov 4, 2008 | 10:26 PM
nemss1's Avatar
have no regrets taking anything out....so far haha (hopefully never wreck)
not sure on the raceweight. gonna weigh the car soon
AC compressor
AC condensor
AC fan motor (entire assembly)
airbag and bracket, passengers
air dam
ashtray & lighter
bumper, front reinforcement and brackets
bumper, rear reinforcement and brackets
coating, under carpet
crossmember brace
dash brace (steel)
door panel insulation
EGR, air pump, & hardware
emblems
firewall insulation
foglights and brackets
gas tank Evac box
grill insert
heater core (w/water)
horn
panhard rod brace, upper
power steering pump, pulley, idler pulley
side impact bars (doors)
spare tire and jack
swaybar and brackets, front
washer fluid pump
windshield wiper reservoir
y pipe hanger (stock, connected to tailshaft)
Old Nov 5, 2008 | 12:13 AM
Duffster's Avatar
Didn't see radio or speakers removed there. . . Hell, you start cutting the speaker wires and you'll be surprised how much there is!
Old Nov 5, 2008 | 08:22 AM
transamsam98's Avatar
hey nemss what size belt you running without your power steering and how do you have it routed? how did you reroute/cut the lines for your power steering any pictures? I am actualy doing that to my trans am now that I was able to get the last bolt off and had some free time
Old Nov 5, 2008 | 11:04 AM
nemss1's Avatar
haha trying to keep the car looking stock on the interior and not sacrifice the music
Old Nov 5, 2008 | 11:16 AM
ndfrsd6's Avatar
thats a good amount of weight though ...dont our cars produce enough music lol
Old Nov 5, 2008 | 12:25 PM
Magnet's Avatar
looks good...its gotta be pretty light, I would keep the front sway bar though, i took mine off for a little while and couldn't stand how it drove... it "floated"
Old Nov 5, 2008 | 08:07 PM
REDGAR's Avatar
what is the abs delete block?
Old Nov 5, 2008 | 08:27 PM
Magnet's Avatar
hey whats the dash brace? i havent heard of it... is it hard to remove? what does it weigh?
Old Nov 5, 2008 | 11:55 PM
nemss1's Avatar
ya true but i love the kickass monsoon system haha. yes our cars do sound kickass! sometimes the music is off for that reason haha
the dash brace is the steel bracing behind the dash that also supports the passenger airbag w/bracket. dash has to come off to remove it. its about 7lbs
ya mine floats w/o the front sway bar. i dont mind it tho. i only use the car as an occasional fair weather weekend car
the ABS delete block is made by billingsley and is a simple bolt-on. remove all the ABS crap and simply bolt on the block in its place. it keeps the stock routing of the stock brake lines
Old Nov 5, 2008 | 11:59 PM
nemss1's Avatar
6 rib, 52.5 belt. i removed the pump, bracket, idler and all the lines and plugged the holes in the rack with bolts. belt runs over tensioner, under waterpump, over alternator pulley, crank pulley, then back to tensioner
type in P/S steering delete with pics in the search and there r a couple of pics
Old Nov 6, 2008 | 09:11 AM
ShiznityZ28's Avatar
Easy 7 lbs for the harness. probably 20 in the whole sound system.
I went threw my factory body harness and removed 60lbs of circuits i ddin't need. another 8 from the engine harness.
Old Nov 6, 2008 | 09:28 AM
ndfrsd6's Avatar
thats one thing im doing over the winter ......wire removal
Old Nov 7, 2008 | 02:57 PM
nemss1's Avatar
well more weight came off today. removed the ABS block and TCS. purchasing the ABS delete block and non-tcs throttle cable. pulling all ABS sensors and reluctor rings when i feel like messing with it haha
