Drag Racing Tech
Vitor Jr. Filter setup
Old Nov 9, 2008 | 01:25 AM
THROTTLEJUNKIES's Avatar
Default Vitor Jr. Filter setup
Ive asked in a couple other sections, so have a few other members. No one can seem to be able to give a good answer to the questions. How would I run a filter on top of a vic jr with carb style TB? Take a look at the pic and let me know if there are any tried and true methods on making this work. Thanks.
Old Nov 9, 2008 | 09:48 AM
3fingas's Avatar
extreme velocity carb hat. You have to trim the hood a little, but no big deal. Though not sure about the victor. It's a little taller than the gmpp, which is what I run.
Old Nov 9, 2008 | 11:45 AM
dlove's Avatar
maybe something like this..
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 9, 2008 | 02:48 PM
I am not going to be running an elbow so that first setup is not going to work. The filter only is what Im planning on but I just need to see some pics of what everyone else has been doing.
Old Nov 9, 2008 | 03:47 PM
Camaro396's Avatar
I don't see any other option. There is simply not enough clearace with your wiper cowl to use a old style round carb air cleaner.
Fire67's Avatar
So you don't need to plumb in the MAF, and IAT?
If that's the case, Edelbrock makes a small foam filter that should fit there.
Old Nov 9, 2008 | 06:29 PM
Ryan K's Avatar
Pathological Modifier
But you have to loose the wipers...
Old Nov 9, 2008 | 11:01 PM
Yeah the wipers are going to have to go without a doubt. The inside of the hood is going to get cut out as well. Maybe Ill just bite the bullet and fab up an elbow this winter. As much as I dont want to that might be the way to go.
Old Nov 10, 2008 | 08:37 AM
Steve Burger's Avatar
LS1TECH Sponsor
Carb tray from Summit, a little L channel and a flat filter. That is what I had planned before the turbo. It is low and will flow enough.
Old Nov 10, 2008 | 08:51 AM
Outstanding, thats exactly what Ive been looking for. Thanks a lot Steve!!
