Drag Racing Tech
Replace rear or trans first?
Old Nov 9, 2008 | 10:01 PM
RedRyder518's Avatar
Default Replace rear or trans first?
Just wondering what you all think I should replace first, my 10 bolt or my 4L60E? I'm building the car to 650+ RWHP but I'm not sure what route I should take. I'm swapping the 10 bolt for a Midwest 9" and the trans for a 4L80E. Anyone have any input??
Old Nov 9, 2008 | 10:27 PM
Duffster's Avatar
Trans. Your rear is still functional? Won't help to replace the rear if the trans you have is losing the power.
Old Nov 9, 2008 | 10:41 PM
Magnet's Avatar
I would say trans too... Just stay away from a sticky tire and your rear will be fin for the time being... Your trans on the other hand might go right away with the 650+ rwhp...
Old Nov 10, 2008 | 08:32 AM
Well, like I said, I'm building the car up first to handle the power. Right now I still have just bolt ons. It seems like the rears die first over the transmission.
Old Nov 10, 2008 | 08:33 AM
BlackScreaminMachine's Avatar
Internet Mechanic
In theroy it doesn't matter, BOTH will need to be changed.
BUT considering the question, the trans will need to be changed 1st, and when you do, a 4L80e at a minimum or Th400 if you dont want the O/D.
the 4LJUNKIE will not live beyond 400 rwhp in stock form, I know, I have had 2 burn up, there are some companies that build higher hp units, but they are a CRAP shoot.
Your at a cross roads, dont waste money that you cannot afford to lose.
Thats why I decided to stop running LTX and move up to LS1's
http://www.fbody.com/timeslips/member.cgi?id=560
here is the car I used to own, running 12 flat on the 10 bolt and no suspenion, on a junk stall and 3.23 gears. I did do a rear and since I didnt increase the stall or gearing, the extra weight slowed the car down to 12.40's
Old Nov 10, 2008 | 06:23 PM
n2ocamaro's Avatar
My trans did not last the break-in period on my stroker. It died at 500 miles. The rear was still functional when I took it out this past march. It held up to several 1.60 60' launches before I added the 9".
Old Nov 10, 2008 | 06:46 PM
Harley-Davidson88's Avatar
A 6 speed car can tear up a rear end pretty quick, but a 10 bolt should definitely outlast a 4L60e in most cases.
Old Nov 10, 2008 | 06:51 PM
Fast_94_Z's Avatar
i would save up extra money and do both at once and get a ncie driveshaft while your at it. personally for a rear end i recommend burkhart chassis' rear end.
Old Nov 10, 2008 | 08:48 PM
Might I add I just bought some ET Streets...
Old Nov 11, 2008 | 12:21 PM
Internet Mechanic
As long as he stays above 1.70 60 foots thats correct, he can get away with it for a while but put 100 passes on it will whine line the rest and eventually fail.
Old Nov 11, 2008 | 01:04 PM
agreed
