Drag Racing Tech
What options are there for 2 step and ign retard?
Old Nov 12, 2008 | 05:59 PM
GrannySShifting's Avatar
Default What options are there for 2 step and ign retard?
Retard stuff looking for something switcheable applying 12 volts or ground. Probably 12 v applied to actvate prefered
Old Nov 12, 2008 | 07:19 PM
JRracing's Avatar
My MSD 6010 or 6LS box does both. BUT it is a ignition box, and I'm sure you don't need all that.
Old Nov 13, 2008 | 05:54 AM
Fireball's Avatar
BS3
Old Nov 13, 2008 | 06:20 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Originally Posted by Fireball
BS3
Agreed, that unit does some trick ****. On fast boost cars thats the only way to fly.
Old Nov 13, 2008 | 10:22 AM
No BS3, just factory PCM for us!
No BS3 until it needs to go over 8500 rpm
No going over 8500 rpm with this stock pump wet sump
No need to do that until its a solid roller.
And no solid roller until it goes 8s or needs a chute!
Fireball you know this man!
Old Nov 13, 2008 | 11:25 AM
bigsticksupra's Avatar
MSD has a new 2 step out for LS series. It will be released soon.
Old Nov 13, 2008 | 05:08 PM
TurboAv's Avatar
I thought I saw something in this dudes Camaro that was made by Lingenfelter???
Old Nov 13, 2008 | 05:23 PM
TurboAv's Avatar
Here it is:
http://www.lingenfelter.com/store/l460095297.html
Old Nov 13, 2008 | 05:38 PM
Dave J's Avatar
I have a digital 7 box and it has both,hell it has so many different retards its retarded
Old Nov 24, 2008 | 11:26 PM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default Lingenfelter LNC-002
Yes, that is our LNC-002 timing controller/launch controller. It has a RPM limit (2-step/launch control RPM) feature and has the ability to retard timing based on an external trigger wire or using a 3 bar MAP sensor (for boosted applications). For nitrous applications you can adjust the amount of timing being taken out and how fast it gets taken out.
The instructions for the device are here.
Originally Posted by TurboAv
