Drag Racing Tech
???how do i remove abs sensors
Old Nov 14, 2008 | 10:02 PM
nemss1's Avatar
Question ???how do i remove abs sensors
in the process of removing the abs system. removed the abs block and swapped for an abs delete block. i have a 4-channel for reference
HOW DO I REMOVE ABS SPEED SENSORS AND RELUCTOR RINGS IN THE REAR?
HOW DO I REMOVE ABS SPEED SENSORS BEHIND THE FRONT WHEELS?
Old Nov 14, 2008 | 11:20 PM
TS6's Avatar
TS6
You don't need to remove them.
The fronts don't come off, they are integrated into the hub.
The rears are pressed on with the backing plates. They don't weigh ****, the wheel is like 10 ounces.
Old Nov 14, 2008 | 11:25 PM
Benner's Avatar
Why you wanting to remove it anyway. I'd kill for my ABS to be working.
Old Nov 14, 2008 | 11:33 PM
nemss1's Avatar
ok thank u much for the input
Old Nov 14, 2008 | 11:38 PM
nemss1's Avatar
im removing alot of weight off of the car. mainly things that the car doesnt absolutely need to run, with exception of the monsoon and keeping the interior looking stock. i have already removed the abs control box. i hardly ever drive the car. its mainly a track car with an occasional fair weather weekend cruise. doing alot of work this fall and winter while its garaged til spring
Old Nov 15, 2008 | 06:02 PM
nemss1's Avatar
do the front abs sensors not come out of the hubs?
Old Nov 15, 2008 | 06:30 PM
Harley-Davidson88's Avatar
The rear sensors are held into the backing plate by a single 10mm bolt. Just unplug and remove the bolt. If you are still running a 10 bolt, you have to pull the axles to remove the reluctor wheels. I just heated them up and was able to pry them off. As was mentioned above though, it's really not worth the effort.
Old Nov 15, 2008 | 06:40 PM
nemss1's Avatar
i read in some threads where they were able to pry the reluctor wheels off with a prybar
would it be possble to pry the reluctor wheels off of the axle and break them off so i wouldnt have to go thru the time of removing axles?
Old Nov 15, 2008 | 06:57 PM
nemss1's Avatar
also i was wondering if i could just drill a holes in the front sensors and break them out completely and remove them that way
im kinda a sucker for removing **** that isnt used or fuctional (or **** i dont absolutely need haha)
Old Nov 15, 2008 | 07:22 PM
It will probably be hard since there won't be much room to work between the backing plate and the axle flange. Only one way to find out. Worst case you will have to remove the axles completely, which really isn't hard.
Old Nov 15, 2008 | 07:27 PM
nemss1's Avatar
im just trying to avoid spending money on new rear fluid since it was changed not too long ago
Old Nov 15, 2008 | 07:35 PM
Capture the fluid in a clean container and place it back into the housing once the cover has been replaced. Problem solved.
Old Nov 15, 2008 | 07:43 PM
nemss1's Avatar
yes true, i dont know y i didnt think of that. thanx for the help
Old Nov 17, 2008 | 10:25 AM
nemss1's Avatar
how do i remove the axles? i pulled my rear cover off and it is a lil diff than the rears ive worked on previously
Old Nov 17, 2008 | 11:25 AM
There should be a small bolt (runs parallel to the axle tubes) on the center portion of the carrier that either holds a pin or a square block (paddle) in place. Once you remove the bolt, the pin or paddle should be able to be removed. Once either is removed (make sure the abs sensors are removed also), the axles can be pushed in and expose the c-clips. A magnet comes in handy in removing the c-clips. Once they are removed the axles will be free to slide out. Just be careful not to damage the seal at the end of the axle tube if you plan to reuse them.
Old Nov 17, 2008 | 05:45 PM
nemss1's Avatar
yup, did all this today! easy as ****! thanx for the help!
Old Nov 17, 2008 | 05:48 PM
no problem
