Drag Racing Tech
???heat shields???
Old Nov 19, 2008 | 10:36 PM
nemss1's Avatar
Question ???heat shields???
plan on removing some heat shields tomorrow.
WHICH ONES ARE SAFE TO REMOVE???
WHICH ONES SHOULD I KEEP???
Old Nov 20, 2008 | 11:01 AM
nemss1's Avatar
anyone?
Old Nov 20, 2008 | 11:54 AM
Magnet's Avatar
I've been wondering his as well.... Mine is a daily driver though so I'm wondering if i should mess with them at all... I don't want any damage..
Old Nov 20, 2008 | 12:14 PM
BlackScreaminMachine's Avatar
Internet Mechanic
The one that comes near the gas tank, thats it. If yo have removed the cats, the rest are not needed.
Old Nov 20, 2008 | 12:57 PM
2FAST4U's Avatar
I agree as with a non-cats y what is the differance in the area with the heat shield and with out.
However I had to remove the passengers firewall one for the turbo. But the only one I still have is the drivers side one that covers the brake lines. the one covering the gas tank had to go for the sumped aluminum tank and I changed to dumped before axle anyways.
Old Nov 20, 2008 | 01:02 PM
nemss1's Avatar
where are all the heat shields located so make sure i have them all off?
Old Nov 20, 2008 | 01:18 PM
Fast_94_Z's Avatar
i removed all of them but i have no cats or anything.
Old Nov 20, 2008 | 01:45 PM
Internet Mechanic
If you have a plastic gas tank i would not remove that heatshield
Old Nov 20, 2008 | 02:16 PM
01sscam's Avatar
Man-Crush Warning
All of mine are removed.
Old Nov 20, 2008 | 06:12 PM
white02ws6's Avatar
not trying to be a dick, but why do you say that? I removed all of mine about three years ago, and haven't had any issues, and i have the plastic tank.
Old Nov 20, 2008 | 06:19 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I hucked all of mine in the trash on my Formula and 93. The reason he brings up the gas tank one is that if you have the massive stock muffler in there that likes to get hot it can cause your gasoline to heat up, expand, and cause problems. If you have a muffler other than the stock one I would throw it away.
Old Nov 20, 2008 | 06:58 PM
white02ws6's Avatar
ahhh, i see, that makes sense. i dont have to worry about that. i got dumps.
Old Nov 20, 2008 | 10:57 PM
nemss1's Avatar
back to my question haha. where is each individual heat shield located so i make sure i have them all off???
Old Nov 21, 2008 | 07:08 AM
tee-boy's Avatar
put the car on jack stands, get underneath, and you will see them.
Old Nov 21, 2008 | 07:24 AM
Internet Mechanic
What I can say is I have a Corsa exhaust which is Larger Diam tubeing, and it sits REAL close to the tank. Then later on I had a new over the axel tube bent and no matter what, it sits close.
With that in mind, heat sheilds are there for a reason. For either comfort, or safety, I am fairly sure if I remove it, id be fine, but that a chance that I am not willign to take.
Old Nov 21, 2008 | 09:48 AM
un17real's Avatar
+1 as are all of mine removed even the plastic under the tires fenderwells
Old Nov 21, 2008 | 10:42 AM
Internet Mechanic
Like said, it is up to the poster to decide. From his other post, I think he took out the door bars so who cares if it blows up.
Old Nov 21, 2008 | 11:29 AM
nemss1's Avatar
i removed the heat shield over the tank/axle, passenger cat/uner the car, drivers cat, fuel lines.
i think that is all of them. not sure tho. is that all of them?
im wrapping the fuel lines and muffler in heatwrap
Old Jan 7, 2009 | 01:26 PM
Magnet's Avatar
Did you happen to weigh the heat shields?
Old Jan 7, 2009 | 07:23 PM
Chrome355z's Avatar
I haven't, but the one by the gas tank can't weigh a pound and the other two are smaller.
To be honest i'm leaving mine in as i'd say 1-2lbs MAX by removing them. All out stripped drag car go ahead, it's not even worth the time for me to do it.
