Drag Racing Tech
Wolfe door panels?
Old Dec 10, 2008 | 07:34 PM
TS6's Avatar
TS6
Default Wolfe door panels?
I've got the doors apart right now doing the crash beam removal (not worth it, pain in the ***!) and was doing some reading and someone said the stock door panels weigh 15 lbs each? I've gotta get my scale out because that seems really heavy to me. Anyway, I was thinking of doing the Wolfe door panels for more weight savings if indeed the stock panels are that heavy. I kinda broke my drivers side armrest off (thought it was supposed to come off, guess not). I could fix it, but I can also fab new panels out of sheet metal very easily. I'd upholster them in dark tweed, mount the switch panel to them, and probably screw the stock armrests on them.
Any input? Are they really that heavy? Anyone have pics of something similar to what I'm talking about?
I did a search and only found a couple things.
Old Dec 10, 2008 | 08:35 PM
BlackScreaminMachine's Avatar
Internet Mechanic
I know some fast cars out there use them and whats cool is glue some Ozite to them and it qualifies for door panels for any race.
Old Dec 10, 2008 | 09:06 PM
Sideways240sx's Avatar
They definatly look super nice. Id love to know direct weight comparision. For me to buy i would have to have run out of other mods, or have a broken stocker like you, and want to replace.
Chris
Old Dec 10, 2008 | 09:37 PM
TJ's Avatar
TJ
i just put a set of 4th gen panels in my car. i had them on and off hundreds of times, literally.
they cant weigh 15 pounds. maybe 5 each at most.
Old Dec 10, 2008 | 09:53 PM
ndfrsd6's Avatar
weight reduction list in the sticky says 18 lbs for door panels so about 9 lbs each...
Old Dec 10, 2008 | 10:03 PM
TJ's Avatar
TJ
maybe they are that heavy.
Old Dec 10, 2008 | 10:06 PM
ndfrsd6's Avatar
im getting wolfe aluminum door panels ....much lighter
Old Dec 10, 2008 | 10:50 PM
TS6's Avatar
TS6
I don't know, I've about run out of mods for now. I could easily make more power but I'd rather just lighten the car and go faster without beating stuff harder. Plus its cheaper to lighten the car than make more power! I like making **** too, so thats a plus. I might make a set and just see how they look. The only thing I gotta figure out is pull handles. I thought about taking the armrest off the stock panels and installing it over the aluminum panel for a cleaner look, sort of. Or I could just cut a hole in the panel where theres no material under it for a "grab hole" instead of a handle. I'm keeping the speakers so I'll just cut holes and upholster over them so the speakers are invisible but audible. I can't think of a way to make the lock slide lever thing work though.
Someone needs to make lightweight racing speakers...
Old Dec 11, 2008 | 11:57 PM
BlackWS666's Avatar
I dunno man, I see what they are gonna look like in my head, and I dont think its gonna turn out like what you want. BUT, we could try it. I do think putting that ozite carpet stuff will make it look If its done at all, go straight aluminum look.
I say go stock panel, and we start tearing out wiring
Old Dec 12, 2008 | 07:14 AM
tektrans's Avatar
I use the wolfe panels. They weigh like nothing, definately worth it IMO.
You don't have to put door handles back on BTW, you can just pull the door from the top of the panel.
Old Dec 12, 2008 | 10:04 AM
TS6's Avatar
TS6
Well I fixed my stock panel so its on for now. I might still make a set this winter, I own a sheet metal shop and have plenty of down time at work. Maybe I could produce and sell them? Wolfe is getting $200 for them, I could do better price wise I think. The template would take me a few hours to get right but after that actually making one would take minutes.
Old Dec 12, 2008 | 11:34 AM
OutlawZ's Avatar
I fabbed up my own panels that I think are better than the wolfe ones... and mine were free with some ingenuity. I have some pics on my photobucket of them after they were upholstered....
and when i did have my door panels off they were heavy.. along the lines of about 9-10 lbs each....
Old Feb 22, 2010 | 10:29 AM
nemss1's Avatar
a couple of questions....
anyone have an idea or pic of what u did for a handle?
anyone cut speaker holes for the front corner factory location?
since im going manual windows, would i just drill a hole for the window crank?
Old Feb 22, 2010 | 10:58 AM
tektrans's Avatar
You don't need a handle, you just grab the top of the panel to close the door
If you are going to keep the speakers you're defeating the purpose of the panels
Yes, you would just drill a hole for the crank
Old Feb 22, 2010 | 11:11 AM
JL ws-6's Avatar
Race your car!
Make some up and PM me when you're ready to sell them.
Old Feb 22, 2010 | 12:18 PM
nemss1's Avatar
well, i figure id keep the door speakers at least for some tunes...unless there is a way to relocate smaller speakers elsewhere. plus the stock door panels are still a bit heavier
thx for the help though
Old Feb 22, 2010 | 06:37 PM
TJ's Avatar
TJ
i dont have an option for speakers in the front being i have 4th gen interior in a 3rd gen. my power window motor is RIGHT in the way.
i have a set of nice 6x9's in the sail panel on the stock 4th gen cd player. sounds good. hardly any bass, but music and voice is very clear. sounds decent.
Old Feb 22, 2010 | 07:42 PM
nemss1's Avatar
im not big on quality on a sound system on this build. as long as i have music for the track days, im OK
Old Feb 22, 2010 | 09:52 PM
InsaneAuto86's Avatar
I just ordered some Wolfe panels. Undecided if I want to cover them in suede or carbon fiber di-noc.
