Drag Racing Tech
2 Step on my M6
Old Dec 13, 2008 | 12:53 PM
98blueSScamaro's Avatar
Default 2 Step on my M6
Looking at Two step's for my m6 setup to get rid of my bog for the line. I am looking for what two steps to go with (brand, and also how to install) So if anyone can give me there input it would help. Thanx
Rob
Old Dec 13, 2008 | 01:32 PM
ndfrsd6's Avatar
i have a synergy ...works great i would def. get a et drag though i could never get my dr's to hold .... you set it to 6000 you come out at 6000 every time full throttle so the et drag will take the punishment well ... your 60 will come down and be consistant
Old Dec 13, 2008 | 01:41 PM
Thanx tom looking in it
Old Dec 13, 2008 | 06:37 PM
smokeum99ta's Avatar
You wouldn't happen to have a website for the synergy would ya? Thats something that I been needing to get for awhile now.
Old Dec 13, 2008 | 07:29 PM
ndfrsd6's Avatar
http://www.synergymotorsports.net/
Old Dec 13, 2008 | 08:01 PM
SuperSlow02's Avatar
Synergy here too, little hard to install but if you have half a brain its not bad
Old Dec 13, 2008 | 11:12 PM
Been all though the site and can't find the 2-step on there site.
Old Dec 14, 2008 | 05:48 AM
ndfrsd6's Avatar
call them on Mon and talk to someone there site is not the greatest ...but if i remember right it was 200 ish
Old Dec 14, 2008 | 06:36 AM
358chevycamaro's Avatar
The Ligenfelter 2 Step simply plugs right in to your existing harness and even has a timing retard function if you run nitrous or a turbo...
Old Dec 14, 2008 | 06:58 AM
ndfrsd6's Avatar
sounds nice they did not have that available when i got mine ....
Old Dec 14, 2008 | 09:32 AM
Sideways240sx's Avatar
I run the LPE unit. (Ligenfelter) It works great the normal usint can do rpm, and retard timing like the synergy unit. For someone who doesn't need to retard timing they are making, or made a true 2 step unit with 2 rpm limits. Very easy to install great directions.
You will love either unit, or if you can find a harlan 2 step used ( he doesn't make them anymore) they are also a great plug and play unit for our car.
Chris
Old Dec 14, 2008 | 10:12 AM
Jditlfm's Avatar
I installed the synergy on my buddies car. Had some problems with it i ended up having to take it apart and un-solder out a transistor and solder two things together to get it to work right. It was a pain in the ***. But it works great now. I guess its a problem they only had with the msd coils but his coils were stock 2001's.
