Drag Racing Tech
suspension set up
Old Dec 15, 2008 | 10:42 PM
Ruckus46Gt's Avatar
Default suspension set up
Ok i'm running a tight converter (protorque 3k), umi relocation brackets, bmr lca, and a prokit. Best 60' on motor is 1.8, and on a 100 shot 1.54. Car doesnt spin on motor its just all I can get on the tight converter. Anyways been debating a midwestern chasis tq arm to get the stock arm off the tranny since i might have cracked the tail housing. Is it really worth it or should I add a bag and swap out back shocks almost looks like it squats to much. What do you think? Here is a video of a 1.57 60' on my car it leaves very soft
http://videos.streetfire.net/video/1...c-9846005bd638
Old Dec 15, 2008 | 11:09 PM
evilbeef54's Avatar
what size ET street rad's are you runnin, and what pressure? Thats the same 60's i'm getting but i know im spinning a lot off the line and pushing the rear out
Old Dec 15, 2008 | 11:26 PM
Ruckus46Gt's Avatar
275/50/15 et street drag radials with at 20psi
Old Dec 15, 2008 | 11:38 PM
Fast_94_Z's Avatar
personally i would go with a burkhart or madman setup if our thinking switching torque arms. alsoif you switch shocks i would switch to afcos and probablly just go ahead and do them all the way around. its a lot of money but its well worth it.
Old Dec 16, 2008 | 12:43 AM
evilbeef54's Avatar
why those two? what do you think about the UMI adjustable ones? just trying to get all the info
Old Dec 16, 2008 | 12:55 AM
Ruckus46Gt's Avatar
I've seen the midwest piece in person and it looks great and for the price you cant beat it. I also know it works with the true duals I have on my car that is why I'm leaning towards that one. Question is is a tq arm really worth it if the car isnt spinning, but at the same time is no where near dialed in
Old Dec 16, 2008 | 11:19 AM
Z-RATED94's Avatar
A good chassis mounted adj. TA will help, no doubt. Why not start with that and an airbag in the right rear? I'm sure your going to see a difference and then on to a higher stall converter.
Old Dec 16, 2008 | 12:14 PM
UMI Performance's Avatar
Our torque arms will work just fine for you... if you need help choosing one please let me know. The Madman is a nice set-up as well but you will find ours to be streetable as well.. so if your vehicle is still going to see some street use you may want to consider one of our set-ups.
Give us a call or post up.. I will be glad to help. Thanks!
Ryan
Old Dec 16, 2008 | 01:41 PM
Ruckus46Gt's Avatar
yea i think i'm going tq arm and bag, then roll bar, then coilovers up front and diff shocks out back...possibely a stiffer spring if need be. I'm holding off on the converter until the tranny goes
