Drag Racing Tech
NHRA requires two return springs for throttle?
Old Dec 20, 2008 | 02:08 PM
JBM's Avatar
JBM
Default NHRA requires two return springs for throttle?
I'm setting up my new motor using an accufab 4500 TB, and have brackets to mount n20 solenoid and throttle cable to the intake. There is a return spring mechanism on the bracket that I'd like to cut off, but I was told I need two return springs per NHRA rule book. Is this one of those rules that is never checked, or does the stock pedal return along with the TB spring fullfill that requirement? Thanks.
Old Dec 20, 2008 | 05:48 PM
mdacton's Avatar
they always checked me for both, I just had one of the billet cable/return spring set-ups. I had a 4150 flange but they mak 4500 also
Old Dec 22, 2008 | 09:00 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Correct, two springs needed on a carb or TB.
Old Dec 24, 2008 | 09:51 AM
tee-boy's Avatar
Default stuck throttle
JUst in case one gets stuck and you can't get the motor out of gear.
seen it happen.
Old Dec 24, 2008 | 10:15 AM
jmill96Z's Avatar
My tech guy is **** as hell. He tried to tell me I had to have 2 on my STOCK OEM TB. This rule is meant for carbs. In fact the IHRA book says carbs. I could see putting 2 in a 4150 TB just to get the guy off your back, but on a stock TB?
Old Dec 24, 2008 | 12:21 PM
tee-boy's Avatar
Default common sense
common sense tells me if it were that big of a deal, someone already would have produced and marketed one of these.
Old Dec 24, 2008 | 07:32 PM
ShiznityZ28's Avatar
I have been checked for both. the 4500 tb feels real light withonly 1 the 2nd feels better.
Old Oct 2, 2010 | 01:38 PM
studderin's Avatar
my 4150 tb has a clock spring on the shafts under the linkage, dose that count as one, so i just nee one external.
Old Oct 4, 2010 | 06:08 PM
jmill96Z's Avatar
shaft mounted springs do not count
Old Oct 4, 2010 | 07:40 PM
ryarbrough's Avatar
I put two on mine... Friction in the cable liked to hang it open with just the internal spring, and I figured I might as well be legal if I was going to add an external spring.
Old Oct 5, 2010 | 09:29 AM
JL ws-6's Avatar
Race your car!
I'd just put the 2 springs on and be done with it, no need to have a headache if you don't have to.
