Drag Racing Tech
25.5 guys question????
Old Dec 22, 2008 | 11:39 PM
nubby1's Avatar
Default 25.5 guys question????
are any of you guys still using the stock steering wheel.or what kind of aftermarket one are you using?and who makes a removable kit for a 4th gen?
Old Dec 23, 2008 | 01:44 AM
Fast_94_Z's Avatar
you could run the stock steering wheel. imrunning an aftermarket quick disconnect kit from burkhart chassis with a grant steerign wheel. manual rank too etc.
Old Dec 23, 2008 | 06:04 AM
MADMAN's Avatar
LS1Tech Sponsor
I have a kit that comes with a Grant wheel and a quick release. All bolt on. Give us a call at 225-673-3533
__________________
www.madmanandcoracing.com
225-343-9029
Old Dec 23, 2008 | 07:24 AM
ATVracr's Avatar
How much? PM if you need to.
any pics of it installed?
Thanks.
Old Dec 23, 2008 | 07:39 AM
mad_steve's Avatar
i'm gonna work on getting a few pics of the installed wheel/hub assembly.
Old Dec 23, 2008 | 08:06 AM
ATVracr's Avatar
Thanks Steve.
Any idea on weight savings? maybe 5lbs or so?
Old Dec 23, 2008 | 08:55 AM
Steve Burger's Avatar
LS1TECH Sponsor
Weight savings is about 8 pounds or so. As fast 94 stated we have a bolt on kit.
Old Dec 23, 2008 | 10:03 AM
JL ws-6's Avatar
Race your car!
Steve/madman, ever look into making a whole complete steering column kit, something that could bolt in with the factory brackets for the stock column? I bet replacing the whole column, with a lw removable wheel would remove a good bit of weight. Probably require some fab work, as everyone would want it in their own spot, but somehow a kit that would work, something that was a cut to lenth type setup.
Old Dec 23, 2008 | 12:17 PM
98CamZ28's Avatar
I had the stock wheel but switched to a grant wheel with a disconnect (don't remember the brand off top of my head but believe it's a grant too.)
Before
After
Old Dec 23, 2008 | 12:32 PM
LS1TECH Sponsor
We can do an entire column kit. We have not seen enough interest to pursue though.
Old Dec 23, 2008 | 01:24 PM
JL ws-6's Avatar
Race your car!
It's something I was looking at the other day when going over a list of weight reduction mods, I figured what the hell, if the wheel can be replaced, why not the whole column. Something like a prostock or chassis car has, stock mounts can hold a wheel with an airbag attached to it that will stop a driver from flying thru the windshield, so they must be strong enough to support that load, so a strait shaft steering column that just holds the wheel should be safe on them, especially with a 5 pt harness holding the driver in place.
One of those things, if ya were closer and needed a car for a mockup, you could use mine.
Old Dec 25, 2008 | 07:27 PM
nubby1's Avatar
thanks for the info guys madman what does the disconect kit cost? and to the guys with the stock wheele is it a pain to get in and out of the car?
Old Dec 25, 2008 | 10:50 PM
biggdogg's Avatar
Heres mine
Old Dec 26, 2008 | 09:19 AM
JL ws-6's Avatar
Race your car!
Big dog did you make a removable tunnel section? if so I'm intrested, I'd love to see some more pic's of how that is set up.
I like the brake master location setup too, under the car like that is sweet (can tell from the pedal setup)
Your column setup is what I was thinking of doing, how much lighter was the whole thing, and how did you mount it under the dash, by the stock column mounts or bars that tie to the cage?
Old Dec 26, 2008 | 09:58 AM
Fast_94_Z's Avatar
i like how you did the shifter inside the console. im basically having my percision shifter mounted right above it with a removable mount so that i dont have to worry about cutting it up or anything.
Old Dec 26, 2008 | 01:57 PM
biggdogg's Avatar
When i got the car it was already done that way i will get more pictures when i get it out of the trailer its raining today..
Old Dec 26, 2008 | 02:18 PM
JL ws-6's Avatar
Race your car!
Big dog is that the twin turbo car that stenod built that was for sale a while ago?
If so shoot me a PM, I'm curious if you don't mind sharing what you paid for it, that car was 100% top notch, I saw what they were asking, but I doubt that it was gonna sell for that kind of $.
Either way, very nice car, and it obviously runs the #'s
Old Dec 26, 2008 | 04:51 PM
biggdogg's Avatar
Yes stenod built the car and they did a great job i already had to add a lot of stuff to it like update to 25.5 cert; fire system; dual calipiers on the rear freshen motor and trans and a ams 1000 so i had put more money in it but it is a top notch car... thanks
Old Dec 26, 2008 | 05:14 PM
MADMAN's Avatar
LS1Tech Sponsor
We put the Precision Shifters in the auto console and flip the indicator. It looks factory.
__________________
225-343-9029
Old Dec 26, 2008 | 10:47 PM
Fast_94_Z's Avatar
^^ i had chuck do a percision on mine moved aboce the console only because for a 2 speed powerglide i didnt want my arm resting on the arm rest. just want to be able to use the trans brake and shift and no have my arm resting there.
