315/60/15 MT DR's installed, no 1/4 cutting!
If you jack the car up by the pumpkin of the rear end to put them on and take them off, then they will clear the bumpstops fine. But if you jack the car up by the chassis, or put jackstands under the chassis, and allow the rear end to come down, the bumpstops will hit. I left mine on, just jack the car up by the rearend.
#38
That looks good! Did you relocate the control arms to get it to tuck in that far? Also, did you use the Wolfe kit or something custom?
I have all Wolfe parts (mini-tub, offset LCA's, adjustable springs), and if I tried sucking the tires in that far on my car, I'd be halfway into the LCA!
