Since this is a drag car few questions . What did you all do with the air bag wires cut them clean or what. Useing the 3196 grant install kit. And the wires to the radio also. Thanks
I pull the column and take everything out including the smart switch, etc. It saves about two pounds. I do still use the factory key switch, because I think it looks better without a bunch of toggle switches.
Mine seems to be rubbing a little bit. I don't know if I need to grind something, tighten it more or put some washers in there. What do you guys think?
We have the quick release hubs and the basic hub adapters in stock, and we can pretty much get any grant steering wheel you want. Give me a call for pricing and availability. 225-673-3533
What did you get to make it work? The installation kit and the quick release or just one of them. I do like the pro stock wheel listed on Madman's site.
Just the quick release hub and pro stock wheel. You don't need the installation kit.
Here is a pic of my Grant steering wheel, i didnt hook up the horn or any wires either, i did have to put a couple washers between the spacer and the column to prevent it from rubbing.
I had to put 2 thick washers in mine and it clears now. Just keep adding till it clears
