passenger side airbag
https://ls1tech.com/forums/drag-raci...-lot-pics.html
The only real pain was the one screw that holds the lower left of the bracket, it comes in from the opposite side, once I found it(actually INSIDE the duct work) I reached behind the dash and pulled it, bag and bracket came out the bottom near the glovebox. Me and a buddy did it in about 2.5 hours.
Bag and bracket was 16lbs.
On mine the VATS module is mounted ON the airbag bracket, wont start without it, ask me how I know.
Remove A pillar covers
Remove door sill plastic deals that run under dash and along side of seats
Remove center console
Remove speedo cluster
Remove upper dash pad
Radio
Glove box
Screws around glovebox
unclip harness clips stick through behind glovebox
Now look to the left of the glove box, down low, you will see a screw coming in from the other side, this is the fun one. Its mate is directly above it, but its easy. These 2 screws hold the left side of the bracket.
drivers lower cover under steering column
drop steering column down
2 bolts directly behind center console under dash
Bolts on top of dash
Nut on each side near door opening 1/2 way up from floor, will have ground wires attached, PUT THEM BACK WHEN DONE.
Dash should be loose, take the hard screw out first, pull the dash back far enough to reach behind it, the screw is down inside the ductwork. I used a 1/4 inch air wratchet with a 4 inch extension.
remove all airbag and bracket screws, bag and bracket will come out the bottom.
DONE, reassemble.
DOnt forget to pull all the insulation out from the firewall behind the dash.
Also if anyone wants to remove the door bars I just did I write up on how with some pics.
https://ls1tech.com/forums/drag-raci...oval-pics.html
I did one on the doors too a while ago that has a few others things you can take out at the same time. Ignore the spam.
http://lsxextreme.com/showthread.php?t=833
