Drag Racing Tech
Drag radials
Old Jan 3, 2009 | 07:25 PM
blockheadnic's Avatar
Default Drag radials
I was removing my trans from my car and left it over night and fluid leaked down my floor and soaked one of my DRs.
What do i do. i cleaned it off and used floor dry to help remove the oil from the rubber. is the tire ruined or will it be fine.
Any opinions
Old Jan 3, 2009 | 07:27 PM
Swift_01_z-28's Avatar
The best way to tell, IMO is to put it on and give a decent run and hope to god it doesn't decide to pop or something stupid like that. I really don't see why tranny fluid would hurt it, but you never know.
Old Jan 3, 2009 | 07:31 PM
Well my car is down and so is my brothers. so testing the tires is a no go.
The spot were it soaked was a little softer until i dried it up.
Old Jan 3, 2009 | 11:08 PM
I don't think it will hurt anything. I could be wrong, but I don't think so.
Old Jan 3, 2009 | 11:53 PM
BadBandit69's Avatar
personally i would prolly just spray some brake cleaner on the spot and wipe it down. that should get ride of any grease or residue.
Old Jan 4, 2009 | 01:07 AM
gangbang malloy's Avatar
i would say smoke that tire up to remove that layer of rubber good
Old Jan 4, 2009 | 01:21 AM
Mean87SS's Avatar
that will also affect the rubber of the tire... even worse then the trans fluid.
Old Jan 4, 2009 | 01:30 PM
I put big o on a rag a wiped the tire down. i guess i will find out this spring. i didnt know if anyone has had this problem, if they had long term problems.
Old Jan 4, 2009 | 01:47 PM
01FbTaWs6's Avatar
usually a DR wont last long enough to have long term problems :-) No, but I wouldnt think it would hurt anything. I would do a nice smoky burnout through to try and burn the fluid out of the rubber once you get the car back up and running.
Old Jan 4, 2009 | 05:59 PM
Will do and will video tape it, hopefully it smokes more than normal.
