Drag Racing Tech
Accufab 4150 TB applications
Old Jan 7, 2009 | 07:38 PM
LS1SpeedAddict's Avatar
Question Accufab 4150 TB applications
Does anyone know if either the 4150 or the 4500 will directly bolt up to a super vic like in this picture or is their some custom modifications?
Old Jan 7, 2009 | 07:41 PM
JBM's Avatar
JBM
4150 will bolt right up. You'd need an adaptor plate to use the larger 4500.
Old Jan 7, 2009 | 07:53 PM
Camaro396's Avatar
What JBM said. 4150 style TB (pictured) will bolt right up. 4500 will need the 2" Moroso adapter plate, which is what I use.
Old Jan 7, 2009 | 08:34 PM
what about to a vic jr.?
Old Jan 7, 2009 | 08:36 PM
Camaro396's Avatar
Yes. Same goes for the Victor JR. I use a regular Victor JR, posted in my picture above.
Old Jan 7, 2009 | 11:48 PM
Speed Density's Avatar
hashtagBMW
If its a 4150 flange then it will work, just make sure the intake you get is. Fwiw, i think all the direct bolt on LSx carb intakes are 4150.
Old Jan 8, 2009 | 04:43 AM
JL ws-6's Avatar
Race your car!
you can have the top of the intake milled and a 4500 flange welded on, then port the top to clean it up if you wanted to, so the spacer isn't a 100% must. This would be a good way to get it on and kep the TB a couple inches lower, IMO FWIW you want to keep as much distance from the top of the hood to the TB as possible to prevent the hood from disturbing/decreasing airflow.
That and if you want to put an air filter on you'll need the clearance.
Old Jan 10, 2009 | 08:46 AM
Thanks guys I'm gonna look at some more CFM numbers and talk to my tuner before I make my final decision.
