Drag Racing Tech
Too much weight on RR caust it to drive left?
Old Jan 11, 2009 | 11:36 AM
FASTFATBOY's Avatar
Default Too much weight on RR caust it to drive left?
On 4 corner scales I have 105# more on the RR than the LR. AT the track I catch myself correcting back to the right after the car settles down after it launches. Is this the cause?
Old Jan 11, 2009 | 01:00 PM
MADMAN's Avatar
LS1Tech Sponsor
Yes that would be the problem.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jan 11, 2009 | 04:29 PM
N2RACINGLS1's's Avatar
So just to make sure you have 105 lbs. more on the right rear tire then the left rear tire with you setting in the drivers seat?
N2
Old Jan 11, 2009 | 11:27 PM
FASTFATBOY's Avatar
N2
Yes.
How much Brian, 50 lbs?
Old Jan 12, 2009 | 05:57 AM
MADMAN's Avatar
LS1Tech Sponsor
10 lbs
__________________
225-343-9029
Old Jan 12, 2009 | 11:26 AM
OutlawZ's Avatar
yup..... what madman said......
my car launches straighter than a mothaF)(&*CA thanks to Madman and my chassis guy......
Old Jan 12, 2009 | 11:45 AM
JL ws-6's Avatar
Race your car!
Yeah that's alot of weight to have on one tire vs the other, 5 to 15 lbs was always the range of weight that the right rear should be heavier then the left, that was dependant on how stiff the rollbar is.
A car with a stock rear swaybar would need more weight on the right rear to leave level then a car with say a wolfe drag bar, if that makes sense.
Old Jan 12, 2009 | 12:14 PM
FASTFATBOY's Avatar
Yeh I did a little redneck mod to the stock rear bar,A little too much. But I can fix it.
Thanks guys.
Old Jan 12, 2009 | 01:02 PM
JL ws-6's Avatar
Race your car!
Someone ghetto rigged a polyurethane end link
Old Jan 12, 2009 | 01:27 PM
FASTFATBOY's Avatar
Nah, what I did was took the steel spacer in between the links on the drivers side, knocked out the round washer, cut off an inch. Put the part I cut off on the bottom and pulled the left side up higher than the right. Loading the right rear. I can adjust it with washers.
Old Jan 12, 2009 | 04:47 PM
Ed Wright's Avatar
9-Second Club
You guys ever check your rear weights with the front wheels up? Put a piece of tubing, or a big, deep 1/2" drive socket on your floor jack, measure the K member to find & mark the center, and jack it up 'till the front tires are off the floor. You'll likely find a lot of RR weight in it. That's with your butt in the seat. The Comp and Pro Stock guys run bigger RR springs. When I still had stock rear springs, I put a 6 cyl '89 Camaro spring in the left rear, took less pre-load in the right PeteZ bar to make it run straight when the wheels were up. My old bracket engine went way past the 60' light before it set down, often in 2nd gear. Nice for it to go straight. This little SS engine doesn't have that tendancy. Loosing 100 ft lbs tend to calm one down.
Old Jan 12, 2009 | 04:54 PM
MADMAN's Avatar
LS1Tech Sponsor
Now you confused the **** out of them ED and gave away a secret!!
__________________
225-343-9029
Old Jan 13, 2009 | 08:39 AM
ty_ty13's Avatar
7 Second Club
make sure and move all the easy stuff to the left.... maybe the battery and bottles if there is no preload in the car.... shouldnt be any preload in the car though if at all possiblle.... i bet that sumbitch is light on FL though... lol
Old Jan 13, 2009 | 09:08 AM
Ed Wright's Avatar
9-Second Club
Damn! I meant heavy LR. Mine was anyway, over 100 lbs with me in it. Sorry, can't even type.
What bottles??
What is "FL"?
I don't know of anybody that doesn't have to run a little pre load, unless they don't carry the front very far out. Carry the front tires out over 100' it had better go straight.
Old Jan 13, 2009 | 09:11 AM
ty_ty13's Avatar
7 Second Club
this is in a perfect scenario with no preload...FL* whoops meant LF
Old Jan 13, 2009 | 09:12 AM
ty_ty13's Avatar
7 Second Club
just saw his sig.... ALL MOTOR.... hmmm no bottles...
Old Jan 13, 2009 | 11:20 AM
Ed Wright's Avatar
9-Second Club
Nope, no easy button.
