NHRA rulles questions
2.) My harnesses are wrapped around the cross bar on the roll cage behind the drivers seat ... is this legal? Do they have to be bolted to the cage?
http://store.summitracing.com/partde...t=SUM%2D890100
DERTY posted some pics of it awhile back and this is the same box he used.
http://www.derty.org/382SR/battery.zip
You can have your harness looped over the crossbar. Technically the harnesses need to have a way to retain them to that location and keep them from sliding laterally across the car. Most that I have seen has been a thin piece of bar welded in parallel to the main bar that you can loop the straps through. I haven't seen many technically look at that, but that's how the rule is.
This winter I'm planning on going over my entire car with the camera and getting some better shots. I realized that some of them are not that great looking. Let me know if you have any other questions.
Most "race" cars don't run alternators and they simply use one or two batteries to provide all the power for their run. In their case you simply cut the battery and the car stops running.
That's why you take the positive wire from the alternator and connect it to the battery side of the switch. You treat both as if they were +12v, because they are. The grounds don't matter. However, don't put the disconnect on the ground wire of the battery. That will do the same thing, everything is grounded to the car and you would only stop charging the battery at that point. On the factory harness you'll notice that the positive wire is doubled up. One goes to the alternator and the other goes up to the fuse box. Same general idea here, you just need to break both of them, then you'll be all set.
