Drag Racing Tech
question on these motor mounts
Old Jan 14, 2009 | 01:30 PM
5_02ls1's Avatar
Default question on these motor mounts
I was looking for solid motor mounts and this all ive been able to come up with...
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
if im reading the ad correctly they bolt the engine directly to the k member eliminating the engine mounts and k member stands...anybody use these.....sorry mods if i wasnt supposed to link to ebay...
Old Jan 14, 2009 | 02:31 PM
Steve Burger's Avatar
LS1TECH Sponsor
For a solid mount, I would go with motor plates and be done. It will free up a lot of room as well. 199.00 for a set and you are ready to go.
Old Jan 14, 2009 | 02:48 PM
5_02ls1's Avatar
im not finding them on your site...can you give me a link???
Old Jan 14, 2009 | 03:24 PM
98CamZ28's Avatar
Those are what i've seen for solid mounts. Those will work with the stock k-member but not with most (if not all) tubular k-members b/c they include a fixed mount to put your rubber or urethane mounts on.
Someone correct me if i'm wrong on this
Old Jan 14, 2009 | 03:41 PM
5_02ls1's Avatar
that would be fine i dont plan on doing a tubular k member...
Old Jan 14, 2009 | 04:00 PM
LS1TECH Sponsor
I need to get them up in a better spot. Here are pics of them on my car.
http://www.burkhartchassis.com/steveberger.html
Old Jan 14, 2009 | 07:08 PM
firefighting1101's Avatar
hey steve are the motor plates weld in or bolt in?
Old Jan 15, 2009 | 12:53 AM
00bluews6's Avatar
i have a raecraft inc k-member and they worked just fine if you have the bank and time do motor plates
Old Jan 15, 2009 | 02:20 AM
98CamZ28's Avatar
See, thx for chiming in I know i've seen some aftermarket ones without mounts so I didn't know if they had spots for the solid mounts. Learned that at least some do.
Old Jan 15, 2009 | 08:13 AM
LS1TECH Sponsor
The J bracket welds to the frame and the plates bolt to that and the front of the motor. It is a very easy install. After that you can remoce te factory pedatle and cear a lot of room. It also becomes easy to pull the motor when needed.
